Author Topic: Bit Copy Of A Mixed Use Hard Drive  (Read 3124 times)
Offline German_EETopic starter
« on: November 08, 2019, 05:22:35 pm »
The hard drive on my workshop machine is used for both MS Windows 10 and Ubuntu Linux, because of this there are six different partitions on the hard drive including UEFI, NTFS and ext3. I would like to make a bit copy of the entire 250 Gb drive for disaster recovery purposes, in the old days I would have used something like Norton Ghost but I am not sure if this program can cope with a mixture of partition types.
The two operating systems don't help here, Linux has trouble reading UEFI formatted drives and MS Windows refuses to recognize an ext3 partition.
So, what can I use to make a bit copy of everything on the drive in one go?
Warren Buffett
Offline andycsmith
Re: Bit Copy Of A Mixed Use Hard Drive
« Reply #1 on: November 08, 2019, 05:34:40 pm »
you could try https://www.clonezilla.org/, the latest version handles UEFI and should cope with Linux as its Linux based software. I use it for taking images of windows PC's.
Online Monkeh
« Reply #2 on: November 08, 2019, 05:37:48 pm »
Eh?!
You have Linux. Use dd.
Offline helius
« Reply #3 on: November 08, 2019, 05:38:47 pm »
# dd if=/dev/hda of=backup.raw conv=sparse iflag=direct & only if your current directory is on a different disk, of course.
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #4 on: November 09, 2019, 01:47:47 am »
Yep, and also if you want the image to be as small as possible, first run zerofree on the Linux filesystems (and equivalent on the Windows filesystems) and, then when you dd, pipe the output through xz or your favourite compression program.
« Reply #5 on: November 09, 2019, 07:54:29 am »
I tried using dd overnight, everything was copied across except the two EFI partitions so the search for an answer continues.
Warren Buffett
Online Monkeh
« Reply #6 on: November 09, 2019, 08:49:54 am »
I think you're searching for a question..
If you use dd to copy a raw block device, everything will be copied. UEFI or not.
Offline Halcyon
  • Global Moderator
« Reply #7 on: November 09, 2019, 09:23:08 am »
Absolutely. dd cares not what is on the disk. It could be complete garbage (encrypted) or blank, it will still image it, bit-for-bit, start to finish.
Offline magic
« Reply #8 on: November 09, 2019, 11:00:40 am »
I wouldn't make images of a disk containing any filesystem which is mounted read-write at the time. This is asking for an inconsistent snapshot which may fail to mount or cause data corruption down the line after restoration.
I have no idea what you mean by UEFI format and EFI partitions.
There is the new UEFI GUID partition tables, Linux of course supports them or it wouldn't even mount its own partition. There are some individual partitions for UEFI use, I know nothing about their contents because my household is UEFI-free but you can certainly image them by reading /dev/sdxN regardless of what filestystem format they contain.
Maybe it's time to ask what exactly have you done and how you know what is copied and what is not.
« Last Edit: November 09, 2019, 11:06:50 am by magic »
Offline wilfred
« Reply #9 on: November 09, 2019, 11:32:39 am »
Be sure to verify your copy to another HDD will work by booting from it. The last thing you'd want is aggravation when you have dire need of it to work.
And I agree dd should be suitable.
