Author Topic: Embedded C language question  (Read 1807 times)
Offline lawrence11Topic starter
« on: March 05, 2020, 06:30:40 pm »
How do I access, and give a value to, precise individual byte of a 16bit (word) array ??
Quickest possible code, on ARM cortex-M. ?
Like this? Well, I guess it dont compile, so this must not be it.
For example.
int16_t bufferk[6];
const uint8_t mask1=1;
while(1){
(uint8_t*)&bufferk[0]=mask1;
Offline ataradov
    • Personal site
Re: Embedded C language question
« Reply #1 on: March 05, 2020, 06:43:39 pm »
((uint8_t *)bufferk)[0]=mask1;
Also, when you say that some thing does not compile, always include the exact error message.
Alex
The following users thanked this post: lawrence11
« Reply #2 on: March 05, 2020, 06:47:29 pm »
A shit, thanks man, it compiles...
Its all about details, should have expected this.
Yeah I knew it was small and error code was not necessary in this case.
Offline brucehoult
« Reply #3 on: March 05, 2020, 08:39:51 pm »
For example.
int16_t bufferk[6];
while(1){
#include <stdint.h>
void foo(int16_t bufferk[6]){
  *(uint8_t*)&bufferk[0]=mask1;
Produces...
foo.c: In function ‘foo’:
foo.c:6:24: error: lvalue required as left operand of assignment
The message is helpful. You're trying to assign a uint8_t to a uint8_t*.
Now you get...
00000000 <foo>:
   0: 2301      movs r3, #1
   2: 7003      strb r3, [r0, #0]
   4: 4770      bx lr
Note that the above code and ataradov's do different things if you change the 0 to another value.
When it is 0, both versions change the first half of bufferk[0], which on ARM is the least significant 8 bits.
If you change the 0 to a 1 then my code will change the least significant bits of bufferk[1], while ataradov's code will change the most significant bits of bufferk[0].
Offline SiliconWizard
« Reply #4 on: March 06, 2020, 03:51:42 pm »
So yeah - this is not specifically an "embedded" C question, more like general C (and would probably be better asked in the Programming section, but anyway.)
You need to brush up on: C pointers, data types, casting and operator precedence. Then you'll be alright.
You got answers and fixes above - but take it as an opportunity to master the above rather than just apply a recipe blindly. Just a thought.
 ;D
