And while an older model of Seagate's 12TB drive has a higher failure rate than the rest it's still not excessive, considering the environment these disks are used (also, Seagate drives tend to be notably cheaper than everyone else, which means HGSTs slightly lower failure rate comes at a premium).
And you still can see that Seagate HDD have much larger failure rate among all models.
No, they don't. And not just because Backblaze only lists stats for a very limited number of models. Stats which, for example, for 2017 list an AFR of 0.89% for their 10TB Seagate Barracuda Pro (ST1000NM0086) which is lower than all three of the listed WDC drives, of which two have an AFR over 2%. So much to "among all models".
And this leaves out all the validity issues with Backblaze's data in the first place.
BTW I've seen plenty of Seagate HDD fail and have a few of them which developed bad sectors laying around. Also it's not like Seagate made one bad series and then it became OK. They repeated it several times. Backblaze buys any HDD they can get cheap, they will buy crap as long as cost benefits outweigh losses due to failure rate. IIRC they once made a statement about that.
Yes, and they also put lots of cheap consumer grade drives in large disk arrays where they are exposed to constant vibrations for which they were never designed for.
Also, Backblaze doesn't list other relevant data like production date/manufacturing charge, firmware level and other things which would be relevant as they affect AFR.
Which is why I already said you have to take their findings with a large grain of salt, because unless you use hard disks in a similar environment then they are meaningless.
BTW, there's a good, albeit older, article discussing the issues with Backblaze's stats:
https://www.tweaktown.com/articles/6028/dispelling-backblaze-s-hdd-reliability-myth-the-real-story-covered/index2.htmlalso, Seagate drives tend to be notably cheaper than everyone else, which means HGSTs slightly lower failure rate comes at a premium
It's not slightly lower. It's about 3-4 times lower on average if not considering those atrocious Seagate HDD from earlier years.
No, it's not. We use a lot of spinning rust in various use cases distributed all around the Western hemisphere (we have >10k drives in the US alone), and I have seen the stats and the majority of drives are within equal margins (but unlike Backblaze we don't shuck cheap external hard drives, we don't buy refurbs, and we don't use desktop drives in a vibration-heavy rack environment; we also record mfg dates/batch numbers, firmware versions and so on, and compensate for environmental factors). And Seagate is really no different than the other manufacturers aside from WDC (because of the strange problems I mentioned earlier). Of course there always can be the odd outliers but as long as its within a reasonable margin (not exceeding 3.5%) we simply don't give a shit. Hard disks are consumables, and notoriously unreliable ones at that.
Because, at the end of the day, even an AFR of 0.09% doesn't mean that the three drives you just bought won't all die within the first week. AFR is a statistical value across a large number of disks, not a guarantee that the specific exemplar you bought will show the same reliability. AFR can be a useful parameter when you buy large amounts of disks (i.e. in the hundreds or more). It's completely meaningless for home users which just buy two, three, four or five drives (a number way too small to derive any useful reliability data from) for their home server or NAS, and who rarely understand all the things that affect AFR anyways.
So all the faffing about AFR is a waste of time, really.
