I built a small free source-available Windows tool called VMA File Behaviour Scanner:
https://github.com/bicurico/VMAFileBehaviourScannerI am the author of the tool.
It is not an antivirus and it does not try to decide whether a file is “clean” or “malware”.
The goal is more limited: it gives a local second opinion for individual EXE/DLL files, especially when VirusTotal or similar services show a small number of generic/heuristic detections.
This happens quite often with small Windows utilities, unsigned tools, protected/licensed software, obfuscated .NET applications, firmware tools, reverse-engineering tools, etc.
The scanner performs static analysis only. It does not upload, execute, delete, quarantine or modify files.
Current features:
- SHA256 / MD5 calculation
- PE metadata and section analysis
- entropy analysis
- import table behaviour classification
- suspicious string indicators
- registry / filesystem / network / process execution indicators
- TXT report export
- JSON XREF-style export for deeper manual reverse-engineering analysis
The reason I made it is that I often see legitimate protected or obfuscated software being flagged by a few engines with generic names such as “Trojan.Generic”, “ML.Heuristic”, etc.
I wanted a tool that explains why a file may look suspicious instead of just showing a scary label.
Example output is more like:
“PowerShell-related string found”
“Network API imported”
“Autorun registry path referenced”
“High entropy executable section”
rather than:
“Malware detected.”
I would appreciate feedback, especially from people who have experience with Windows tools, firmware utilities, reverse engineering, malware analysis, or false positives:
- Are the categories useful?
- Is the scoring too conservative or too aggressive?
- What static indicators should be added or removed?
- Is the report wording clear enough to avoid false certainty?
- Would this be useful when checking small downloaded Windows tools before running them?
Again: this is a static triage / second-opinion tool, not an AV replacement.
