It sounds like Kubuntu is overriding the default FAT mount with tz=UTC option, see mount(. It works as expected on my Linux distro, times are handled correctly. So you have to figure out how to disable that override on your distro.
There is more on this issue.
This is the tip of a problem on the whole buntu thing.
- Automated package management requires a proper time synch ...
- which should be set on the "GUI" thing using that applet thing (EKkkkkS...)
- Several buntu variations require a proper adjust which in several cases present different results
DEPENDING ON THE TIME ZONE YOU ARE around the globe..
- When things are totally weird some folks suggest using NTP (aka network time daemon)
- so... the system will use a synched time zone where packages will have sane time stamps.
OK. That said .. I have solved some issues like this using a displaced zone so the system will not make my life miserable forcing weird time configurations.. and worst ... screwing the RTC clock every boot you make
Your mileage will vary.. BUT CERTAINLY THE PROBLEM IS WAY BELOW THIS..
The problem is this fu8ckkkk AUTO PACKAGE UPDATE thing requiring your system to use a time stamped date...
Slackware and several other distros (not based on APT and *buntu)
can set TZ properly which will never ever present such odd results..
Your mileage will vary .. try each one in order..
setting your zone.. then
setting a NTP daemon ..
or (last resource ) manually setting TZ.
Be warned that the last one may give you time problems when upgrading packages..
(aka package not ready to upgrade no sever XYZ. etc..etc...)
alternative to change pack repos.
Paul
