Y'all need remedial English lessons.
"This house is 10 metres square." - The house is square, it has walls 10 metres long, it has an area of 100m2.
"This house is 10 square metres." - This house has a floor area of 10 m2, it may be any shape including irregular.
Disagree.
“10 square meters” = 10 m2
“10 meters square” = 10 m2
“10 meters squared” = 10x10m = 100 m2
Not that I would in any way recommend using anything but the first.
Consider this bit of usage: Q:"How big is it?", A:"About 6 inches square.". What do you expect? Something thats is six inches by six inches, or something that is \$\sqrt{6 {in}^2}\$ by \$\sqrt{6 {in}^2}\$? Saying something is "X units square" is quite distinct from saying that something is "X units squared" - in one the units are linear, in the other they are areal.
Nooooo, really?!? I’m so glad you spelled back to me
the literal point of my reply. I just disagree with you on which one is which. (I am open to being convinced otherwise, though.)
With that said, oddly enough, the answer to me depends on the unit: for meters, I expect it to mean \$\sqrt{6 {m}^2}\$ by \$\sqrt{6 {m}^2}\$, but in inches, a 6” x 6” square. Perhaps it has to to with context (a couple of inches being far smaller than a couple of meters), I’d have to think about it.
As to:
Noting that you've converted that to "metres squared" with that [d].
Wow, you noticed! Thanks, Cap’n Obvious!
What would you say if if was any other unit, say noise calculations. "The amplifier has an equivalent input noise of 0.5 \$V^2 {Hz}^{-1}\$." - "The amplifier has an equivalent input noise of 0.5 volts squared per Hertz.". You wouldn't square the stated figure of 0.5 expressed in the units \$V^2 {Hz}^{-1}\$, neither would you square a figure given in units of \$m^2\$ - "metres squared".
Honestly, this seems to be an area of contention, with the meter clearly getting special status in common usage. (Whereas I completely agree with your example of V squared.)
Look at e.g.
https://www.quora.com/What-is-the-difference-between-square-meter-and-meter-squareThe SI apparently states unambiguously that 10 meters squared = 10 m
2. However, nearly every reply (including ones by mathematicians) say that 2 meters squared = 4 m
2. The SI does not, however, address what “10 meters square” is supposed to mean.
Hence why I agree that one should stick to the wordings “10 square meters” and “10 x 10 meters”/“10m x 10m”, which are totally unambiguous and avoid the ambiguous phrasings.
Can we agree, though, that the OP is completely, unambiguously wrong in claiming that “10 square meters” is
not 10 m
2?
If I say "This house is 10 metres square"
it produces the text
"This house is 10 m²"
which is correct.
If I say "This house is 10 square metres"
it again produces the text
which is incorrect.
iOS 12.5.1 on iPhone 6.
