Most people only upgrade their PC every 3 or 4 years if that. So high ram prices are not that much of an issue to 99% of people.
Where do those 99% of people get their insider information on planned cartel activity so they can plan around it? I missed the memo, so my needs aren't out of phase with their abuse.
It's not like a 4 or 5 or 6 year old PC either dies or becomes obsolete overnight, forcing an upgrade. Delaying an upgrade you were thinking about by 1 or 2 more years is unlikely to be very painful.
My current computing arsenal of things I use pretty much every day is:
- 2026 (May) SpacemiT K3 RISC-V SBC, 8 performance cores + 8 "AI" cores that can also run regular apps at ~40% the speed of the main cores. 32 GB RAM. Good for running local 30B LLM models.
- 2023 VisionFive 2 4x 1.5 GHz cores, 4 GB RAM. Runs monitoring / control / logging for my solar power
- 2023 Lenovo i9-13900HX laptop with 24 cores (8+16) 32 GB RAM. My workhorse. Normally lid closed, used from the Mac. I was considering an upgrade to 64 GB, now on hold
- 2022 iPhone SE. Plenty fast enough, battery life still acceptable (can be replaced anyway). With 4 GB RAM and recent OS/apps apps quitting and restarting is just starting to be painful (especially X)
- 2020 M1 Mac Mini with 8 cores (4+4) and 16 GB RAM. It's what I sit at all day. It has a 32" 4K screen.
- 2015 12.9" iPad Pro. Used every day, but not usually for long and the battery lasts a couple of weeks. Can't run recent OS, but so far no problems with web browsing or media payback.
Also plugged in with a network connection and turned on when needed:
- 2018 Threadripper 2990WX, 32 cores, 128 GB RAM. The i9-13900 laptop is faster on everything that can run in 32 GB RAM, and uses a lot less electricity.
- 2012 Mac Mini i7-3720QM, 8 GB RAM running Ubuntu 24.04.
The only thing I'm likely to buy in the next 12-24 months is a next generation RISC-V SBC, probably a Tenstorrent Atlantis (Ascalon-X CPU cores). They are improving very rapidly.
An updated iPhone would be next on the list, but I don't want to move away from a physical home button and Touch-ID.
