As amazing as it is, it's even more amazing that it's all working on board boards and has no bad connections
Spending so much time and effort on something that is so short-lived is kind of crazy.
Either that, or it may be a lesson in wisdom.
Why, when it is a hobby you just have fun doing it.
I can see this one as very frustrating though, when one of the many wires acts up with a bad contact. Good luck in debugging that.
"Just because I can and I want to" is a valid reason for doing something heroically obtuse.
I think we can assume that the builder didn't sneeze or slam the door while testing it.
However, he is honest, and notes problems that come as
absolutely zero surprise (my
emphasis)
Noise was a big problem. The clock design I came up with was very sensative. This meant that a
transient voltage spike/drop would often cause an unintentional clock step. A couple of times I had problems that were solved by simply adding capacitors to make my power supply more stable. I also discovered very late into the build that my
clock only works with my oscilloscope plugged into the wall. It doesn't need to be connected to anything, or even turned on. Just plugged into the wall. The moment I unplug it my computer goes haywire."
https://naberhausj.com/miscellaneous/8-bit-computer/page.html
