Author Topic: Need m.2 male to USB breakout card/board  (Read 2727 times)
Offline hap2001Topic starter
« on: August 13, 2024, 04:30:35 pm »
Hi. I know it's a weird request because I cannot find one easily.
The only one matches is this: https://www.zebax.com/index_files/page1270.htm
But $85 each is too expensive for what it is, also buying from a random site is not a good idea.
I just need an adapter, which one end is male m.2 (A+E or E or B key, which A+E is most wanted), the other end is the 4 pins of USB 2.0, it's okay if it expose more.
I've searched for a long time with no avail, anyone have a good source? Thanks.
« Last Edit: August 13, 2024, 04:34:30 pm by hap2001 »
Offline Nominal Animal
Re: Need m.2 male to USB breakout card/board
« Reply #1 on: August 13, 2024, 05:28:35 pm »
Would fabbing your own at JLCPCB, PCBWay, et cetera, with gold fingers be out of the question?  1U ENIG 1.0mm thick plus gold fingers at JLCPCB would cost about $30 for 10 plus shipping.
EasyEDA has M.2 A+E card modules (schematic matching the pinout with the exception of reserved pins 59,61,65,67 having the PER and PET names swapped, and 2230-sized board) which would make it very easy to do.
You need to route pin 3 to D+; pin 5 to D-; pins 1, 7, 18, 33, 39, 45, 51, 57, 63, 69, 75 to GND; and obtain 5V USB from somewhere.  The M.2 A+E only has 3.3V available (on pins 2, 4, 72, 74).  You could easily add a Microchip USB251xB USB 2.0 hub to the card to extend the number of USB ports; see the PCB Layout Guide for USB251xB ic's.  JLCPCB even has USB2514B-AEZC-TR (4-port) in stock for assembly for $1.5 apiece, so you could have these fully made for you.
Otherwise, try adding "NGFF" to your search terms as an alias for M.2.  That way, you'll find stuff like the M.2 A+E USB 2.0 dual-port hub.  I am a bit suspicious about EMI and EMC noise from their 3.3V to 5V boost converters, though.
Offline mariush
« Reply #2 on: August 13, 2024, 05:34:22 pm »
M.2 may or may not contain USB - on motherboards some m.2 slots designated for WiFi may have usb support for bluetooth part of wireless cards.
If your m.2 slots have at least one pci-e lane, it may be easier to just get a m.2 to pci-e x1 / pci-e x4 slot  and connect a low profile usb controller card to that pci-e slot.  You can use riser cables if needed.
