Hi:
I have an old Thinkpad X201 here.
Model/Type: 3113-X06.
Now, I almost never cross-post. But this time, I posted a similar question on another forum. There, I asked: "Can anyone tell me the exact model of the AC adapter for it? Some of the photos on the web suggest they use a typical barrel connector with OD = 7.9mm and ID = 5.5 mm. However, the charging port on my X201 doesn't look like one that would accept a standard barrel connector. I've actually never seen a connector that looks like it before.
They replied:
"Your DC-in port is damaged beyond repair with 2 bent contacts and a missing center stub."
"That port is badly damaged-- the plastic part in the center is completely gone."
In my reply, I stated:
Your thesis is that my power jack is missing a large, wide chunk of plastic in the middle of it? And if so, why do I see zero signs of a break in said plastic in the jack? As I said, the picture you posted looks nothing like my jack. The jack in the photo you posted also doesn't show the two small round contact pins in the middle of my jack, nor the two more rectangular-shaped contact pins on each side of them.
Their reply was that my jack is severely damaged, and that the yellow center plastic was missing, and the contacts were normally hidden inside it.
Photo of my, allegedly damaged jack
Photo of what they claim is the same jack as mine, but undamaged:
Does everyone agree with this? I'm finding it a bit hard to believe.
