I just received a couple of two-touch capacitive touchscreens from Buydisplay (
2.8" with FT6206 and
3.5" with FT6236), but I'm leaving for the frozen wastes of Hoth for at least a couple of weeks.
The 3.5" one is almost as large as the touchpad on HP EliteBook 840 G4; the 2.8" one is about 3×4 fingertips.
If one intends to have both buttons and a pan/zoom/scroll area, I think an even larger one, say
4.3" with 5-touch FT5206 would be even better. (The
2.7" e-ink modules are only a little bit taller (57.3mm × 38.2mm visible area, 70.4mm × 45mm physical) than the visible area of the 4.3" touch panel (95.6mm × 54.5mm), so two 2.7" units would cover the entire area, more or less. Or one unit for the button area, leaving the pan/zoom/scroll area without e-ink. Modularity for the win, methinks.
