So was it worth it
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif.pagespeed.ce.5xOqKkq0Co.gif)
Followed Steves instructions by the numbers in the video above and got reduced latency memory timings to stick and prove stable under stress testing
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif.pagespeed.ce._JElyJQqdB.gif)
Old spec was 3200 CL16 Corsair Vengeance LPX finished up at a modded CL14 using the settings straight from the suggested Dram Calculator.
Result is a bit over a 3% improvement on PCmark as per below and a marginal improvement on 3D mark but it is heavily weighted on the GPU. I did try running the memory at a higher clock (3400) and slower calculated timings and it failed and reverted the BIOS back to the old one. It is possible with playing I guess to make this work but it pushed the latency back to 16 again.
Taking the 3+% gain and calling it done until I get to my 2400G build then there will be definite gains to be made as the RAM is shared for graphics duty.
