This the most disappointing interface standard ever.
Do you agree??Just about every USB device I've ever owned, from cheap to expensive, can still connect to a modern computer, and interface on the hardware level, even if the software drivers have long been outdated.
Thunderbolt was presented as a faster, low latency interface, with both the motherboard hardware and connected devices being considerably more expensive. My main use for thunderbolt has been audio interfaces. Thunderbolt 2 was fairly quickly superseded by TB3 and with it came the change to a USB-C plug over the Mini Displayport.
At first things were OK, because you can buy TB2>TB3 adapters, but over time the software and BIOS seemed to degrade. For example on MacOS Catalina, TB was very reliable and could be hot swapped. Upgrading past that resulted in hot swap failing to work (computer had to be booted with devices already on and connected). Dropouts began to occur, requiring a reboot. These could have been a result of OS, BIOS or device firmware updates. Who knows.
But what really takes the cake is that apparently TB4/USB4 controllers have now dropped support for TB1/2 devices (meaning they HAD support for them). So now my expensive TB interfaces are probably going to be USB2.0 interfaces going forward.
Of course I figured this stuff out after paying a premium for a USB4 motherboard
