Note: I'm not saying that what you want is wrong, I am only describing why you are having trouble finding a solution, and what solutions I (and others) go for instead.
There are three different things on a Linux system to consider for backup strategies: User files, system executables and libraries, and configuration files.
If you want a true snapshot of a running system, use LVM between hardware and actual filesystems. LVM lets you make a snapshot of filesystem contents you can copy at leisure, and then remove the snapshot, without affecting the running filesystem at all. The only downside is a bit of complexity in your backup scripts (it has to make the snapshot, mount it, copy it, unmount it, and remove the snapshot) and temporarily increased disk space requirement –– changes to files during the snapshotting requiring new disk space, which you can cater to by slightly overprovisioning the partitions by keeping the LVM volumes slightly larger than the partitions using them.
LVM also makes it easier to migrate a running system across storage hardware.
(Unlike Windows, Linux does not stop processes from accessing files, even executables, in use at the same time. Because of the Unix inode model, executables belonging to running processes can be deleted and renamed, just not modified – except via copy-modify-rename cycle, of course. The above LVM snapshotting is not a requirement, just one option that provides a true snapshot in time, as opposed to a per-file snapshot taken sometime during the backup process.)
I partition my storage so that system executables and configuration files are on one partition (root), and user files are on another (home). I only backup user files (/home) and configuration files (/etc and some subtrees under /var, excluding for example /var/lib/snapd and /var/run). I do not backup system files, because the configuration files includes the list of packages currently installed. (On Debian derivatives, you can obtain that using e.g. apt list --installed; this list is extremely useful in bringing back a system from the dead.)
Because of my backup idiosyncracies (DVD-Rs, MicroSDs), I happen to use tar -J instead of rsync. The difference is that I have a rotating set of full backups instead of incremental ones.
Because I backup user files, I rarely restore a system exactly to how it was. Instead, I use the opportunity to upgrade to the latest stable versions, verify key applications work, then copy over the relevant user files (including email archives, some application configurations, and so on) selectively. I usually also delegate some of the rarely used user files to permanent storage, and leave them out from the new system.
I also use the exact same mechanism to migrate to a new Linux distribution.
This has worked well for me over two decades. I have had a motherboard b0rk (a CPU voltage regulator literally cratered), a couple of HDDs go bad, lose temporary data on USB and MicroSD Flash media; so I have needed to rely on this process at least three times (plus another three or four times voluntary migration using exact same mechanism). I have not checked how efficient this is time-wise, other than that I usually "lose" the whole day (mostly in deciding what exactly to switch to, and testing a bit before committing), but other than a couple of days work product, I've not lost anything important.
Most importantly, it does not bother me when this happens: I know I won't lose much, and the balance can even be a positive change.
Those relying on Linux as a tool, with the technical ability to do this, tend to do some variant of this.
A tool that lets one go back to a previously snapshotted state is less useful than one that lets you migrate to a new system.
This is why "single button backup and restore" solutions just aren't that popular in Linux – except for users who look to duplicate Windows functionality. The free/open source folks are mostly in the former group, and the latter group is serviced by paid proprietary software vendors.
If you have neither the time nor inclination to set up such a backup system suitable to your work flow, I recommend you check the Linux distribution you use for backup tooling. You'll find quite a few tools that can automate this for you, with both command-line and GUI interfaces. Some only provide the backup tool and expect you to add the triggers yourself (usually in crontab, to be run at specific times), some provide the full kaboodle. rclone is pretty commonly used, if you use cloud storage for your backups (but do consider using the crypt remote, so that the cloud backups are encrypted and decrypted on your local machine).
If you have a virtual machine running Linux, I recommend making a snapshot, then installing one or more of the backup softwares, and seeing how their UIs feel like. Instead of uninstalling, just restore the machine to the previous snapshot; this saves time, and leaves no uninstaller crumbs lying around.
I habitually do this – run another instance of Linux in a virtual machine on my Linux machine – for exactly this purpose: testing software I'm curious about, but unwilling to commit my work environment to.
