No.. never..
You need some external devices to measure this.. not simple
Externally you can even use these "AC Power meters adapters"
to check dynamic outlet power draw...
But with GPU the bottom line is way below this..
GPUs put
surges and
spikes on the PSU..
They are very fast and can cause the REGULATION TO FAIL
and a fast drop fo the voltage which is hard to see with common instruments..
but the CPU may reset or even halt on some of these drops..
Oversizing PSUs was ever a simple but expensive and unreliable solution
Crypto-mining setups use 2 or 3 PSUs one for each GPU to avoid resets on HIGH current spikes..
Ultimately you can not see this surges (i posted a very good explanation from IGORs LAB about this.. somewhere... ) unless using complicated measures...
The BIOS can only setup simple things like turning OFF iGPU (less power draw)
Under clocking the GPU... less power draw..
But this is not solution.. you need power +a separate connector..
get rid of the PCI lanes 75W limits....
a power hungry PSU...
GPUs as of today are insane power devices..
You need to compare the best affordable solution..
**IF** your card is working but you have lack of power for it..
but...
if the card is bad with thermal bga problems
they will manifest on other mobos...
Paul
PS forgive me if this is not the topic.. i just made a fast search of an old issue..
https://www.igorslab.de/en/power-recording-graphics-card-power-supply-interaction-measurement/
