Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2313406 times)
0 Members and 33 Guests are viewing this topic.
Offline Rémi
« Reply #2725 on: June 29, 2017, 09:07:47 pm »
More than enough, I love test gears  :P
Offline Phil_Tech
« Reply #2726 on: June 29, 2017, 10:30:28 pm »
thanks, I previously had a "junk yard" theme going, so this is quite a change for me.
Lots more stuff to go back in there yet which is why it still looks clean.
Also want to get some blue ESD matting for the benchtops. Does anyone know where is the best place to buy that in Australia?
Offline PTR_1275
« Reply #2727 on: June 29, 2017, 10:50:04 pm »
I got mine from mektronics. They have a roll of 900mm wide x 10 meters long that I just cut to length. They also sell the clipsal earth point connectors (439as if I remember correctly) and the press studs, cables etc... for connecting the mat to the earth point.
The following users thanked this post: Phil_Tech
Offline SkyMaster
« Reply #2728 on: June 30, 2017, 03:01:21 am »
Currently revamping my work repair lab
Phil - Melbourne, Australia.
What is the height of the ceiling in your lab?
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #2729 on: June 30, 2017, 04:22:46 am »
So many benches with just a laptop as PC workstation role. I can't help myself but feel claustrophobic on any screen less than few 26-30" or single 40-43" 4K doing R&D work...  :-//
Offline VK5RC
« Reply #2730 on: June 30, 2017, 12:11:40 pm »
But just think of how many bits of test gear could fitted in the area of shelf/workbench taken up by such a large screen! HiHi  :blah:
Edit VK5RC lab Nth West corner Photo
« Last Edit: June 30, 2017, 12:15:12 pm by VK5RC »
Offline rdl
« Reply #2731 on: June 30, 2017, 03:01:29 pm »
I find laptops clunky and clumsy to use compared to regular PCs, mostly because of the attached screen which always seems to be in the way. I'd never choose to use one at the bench. A large screen that sits in one place and takes up little working space and a keyboard/mouse that can be moved completely out of the way if needed is much preferable to me. I guess if you can only have one computer, and also need to move it one from one room to another, a laptop would make sense.
Online PA0PBZ
« Reply #2732 on: June 30, 2017, 05:17:29 pm »
I have my monitor on the back wall of the bench, which is otherwise unused. Together with a wireless mouse and keyboard it takes zero space away :)
Offline hammy
« Reply #2733 on: July 01, 2017, 12:03:07 am »
Please tell me more about these three spotlights.
Offline VE7FIM
« Reply #2734 on: July 01, 2017, 07:40:55 am »
Monitors take up way too much space that could be used for test gear. I originally had a 32 inch monitor mounted in one of the half-racks on my main bench, but ran out of space for equipment. That problem was solved (for the meantime) by mounting the monitor on an arm attached to the wall. It works very well, and I can move the monitor around depending on what I'm working on and easily access to the equipment behind it.
Online PA0PBZ
« Reply #2735 on: July 01, 2017, 08:22:22 am »
Ah yes, those... Halogen down lighters saved from a kitchen, thought they where too cute to just throw away. I should really replace them with LEDs because the light is quite yellow and they consume a lot of power, but well, you now... :-X
The following users thanked this post: hammy
Offline Phil_Tech
« Reply #2736 on: July 02, 2017, 05:51:21 am »
it's pretty tall - about 6 metres. I'd like to put in a mezzanine floor one day to make use of the extra space.
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #2737 on: July 02, 2017, 08:43:55 am »
Looks like you could make use of the new spot welder that I am developing :D
https://www.eevblog.com/forum/projects/guesses-on-what-i-am-attempting-here/
Now that my workshop room is finished, it is luckily progressing faster.
Before
After
We Are The Watt - Resistance Is Futile!
Offline German_EE
« Reply #2738 on: July 02, 2017, 09:45:49 am »
So far we have 111 pages of workbench geek porn, does anyone else think that this is quite normal  8)
Should you find yourself in a chronically leaking boat, energy devoted to changing vessels is likely to be more productive than energy devoted to patching leaks.
Warren Buffett
Offline GreyWoolfe
  • NW0LF
« Reply #2739 on: July 02, 2017, 02:50:00 pm »
No where near enough.  How many members are there on the EEVBlog forum?
Offline tatus1969
    • keenlab
« Reply #2740 on: July 02, 2017, 06:42:46 pm »
that is directly correlated with https://www.eevblog.com/forum/chat/test-equipment-anonymous-(tea)-group-therapy-thread/  :o
Offline bsudbrink
« Reply #2741 on: July 05, 2017, 07:32:00 pm »
I enjoy this thread and check it regularly.  I intend to contribute soon myself...
Dear EEVBLOG,
I never thought I'd be making a post like this but the I finally got my bench just so...
Offline Mattjd
« Reply #2742 on: July 05, 2017, 07:35:25 pm »
I had to post this for the beginners contest, so I thought I'd share
http://imgur.com/a/A2EsL
Offline Dielectric
« Reply #2743 on: July 05, 2017, 09:50:13 pm »
I tried the vertical monitor thing on my secondary display, but found that the viewing angle was pretty limited since they normally design for left-right and not up-down.  Do IPS monitors behave nicer than older TFT ones?
Offline TerraHertz
    • It's not really a Blog
« Reply #2744 on: July 05, 2017, 11:30:16 pm »
Multimeters velcro'd to a wall! I like this idea! Only, also needs hooks for the coiled leads, since I wouldn't want to have to unplug them all the time.
111 pages of pics of electronics labs. Nice, but here's some non-electronics. My mechanical workshop at the moment. In which I'm finally getting to mount a nice big pneumatically operated gate valve to my vacuum chamber. And soon after that, a turbo pump going on too.
Offline AF6LJ
« Reply #2745 on: July 06, 2017, 03:08:26 am »
Vacuum components always stick out like sore thumb :)
COOL...
Sue AF6LJ
Offline TerraHertz
« Reply #2746 on: July 06, 2017, 05:23:56 am »
COOL...
Ha ha, you wouldn't think it so cool, if you were the one having to drill eight 8.5mm holes through 12mm thick stainless steel. With a hand electric drill, since the thing is too big to fit in my drill press. Currently doing just the small pilot holes. Arrgh.
In this pic the square bar of plain steel is an alignment jig, since the holes have to be accurately perpendicular to the surface.
So far I didn't break the small pilot bit (5/32") but I expect I will, possibly multiple times. Just got back from buying a 10-pack as a precaution. Getting it to bite takes both hands AND pressing down on the drill with my chest. For those who've never drilled stainless, the trick is: low drill speed, but apply lots of pressure or none at all. No in between, since allowing the drill bit to rotate on the work metal without cutting, almost instantly work hardens the stainless. Which then almost instantly blunts the drill.
Fine control is difficult when you are straining hard.
Edit to add: Btw, if anyone needs big O-rings in Viton (a fluoroelastomer, very inert and withstands high temps), I found that Aliexpress has them for a reasonable price. For eg:
  https://www.aliexpress.com/item/New-170mm-x-160mm-x-5mm-Green-Viton-O-Rings-FKM-Hole-Sealings-Gasket-Washer-5pcs/32453184696.html
« Last Edit: July 06, 2017, 05:36:32 am by TerraHertz »
The following users thanked this post: AF6LJ
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #2747 on: July 06, 2017, 05:44:39 am »
 :o :o  Dayum!!  That does not look like fun in any way, shape or form!  Drilling stainless is a female dog for sure.  I wish you success.
-Pat
« Reply #2748 on: July 06, 2017, 07:02:31 am »
Everybody needs a hobby.  ;D
Btw, if you are drilling holes in stainless steel, I can really recommend these drills, they are excellent:
http://www.ebay.com/itm/331812291571
http://www.gewindebohrer.de/shop/catalog/product_info.php/info/p6855_HSSE-Extreme-Drill-Bit-Kit--0-1mm-steps--6---10-mm.html
Offline TerraHertz
« Reply #2749 on: July 06, 2017, 07:46:40 am »
Nice drills, and I wish I did have a set going up in 0.1mm steps. BUT... 197 Euro = Au$294.43
My local supplier sells cobalt alloy drills too. Could have bought some this morning  but I knew from experience I can drill stainless with ordinary HSS bits. Blunting is not the problem; breaking the bit due to using a drill guide and there only being a few mm between the guide and the drill chuck is the problem. Have to be extremely careful not to tilt the drill.
Anyway, pilot holes all done, no drill bit breakage. Just had to resharpen it every 2nd hole.
Annoyingly, afterwards I realized I'd put the spacer disk on upside down when drilling the initial marker holes using the disk as a template.
I didn't make that disk, and whoever did it wasn't terribly accurate with the hole positions. So when it's flipped over the RIGHT side up, there's a slight misalignment of the holes. Just one more thing to deal with. Annoyed with myself now.
That disk came with the gate valve. It's a bodge job and for that and other reasons I'd have preferred to make a better one, except my lathe can't spin things that size.
« Last Edit: July 06, 2017, 07:53:52 am by TerraHertz »
