Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2313216 times)
0 Members and 17 Guests are viewing this topic.
Offline neo
  • The specialist.
« Reply #2775 on: July 08, 2017, 08:14:54 am »
In case you are wondering what i mean by officially entered the hobby i went to an auction and bought about 80 years of a, deceased, naval engineers collection dating all the way back to the 30s. It was at that point i decided i was into electronics for better or worse.
Offline rolycat
« Reply #2776 on: July 08, 2017, 10:26:00 am »
You could reduce the sag considerably by distributing the weight more evenly. A sheet of high quality plywood (at least 9 layers), cut to fit and placed on top of the shelf should help.
Offline BFX
  • Country: sk
« Reply #2777 on: July 08, 2017, 11:07:17 am »
Lab update  8) New k2400 SMU, Marconi power meter, Datron 7.5 DMM and so on
« Last Edit: July 08, 2017, 11:09:18 am by BFX »
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2778 on: July 08, 2017, 11:59:30 am »
Looks like you reached the ceiling - excellent!  :-+
The following users thanked this post: BFX, Vtile
Offline ez24
  • L.D.A.
« Reply #2779 on: July 08, 2017, 04:47:39 pm »
I'm open to suggestions, i can't do under the shelf support due to the shelf below it being full and i quite like the way that shelf below it is set up. I just said it was smiling as a joke, easier than saying "I have little clue what to do here."
To be fair though the camera does kind of exaggerate the sag and the shelf is rated for 200 pounds.
Finally someone else using a Costco shelf.  I took two and remove the top 2 shelves and put a 4x6 board on top of them to make a standing table (it rocks).  I also took two and turned them 90 degrees and put 8 foot boards on them for more shelf space with a 6 foot Costco folding table between them as my sit down table.  No screws or nails.  I used a 2x3x8 foot stud across the top and zipped tied a Costco LED shop light to it.
I am amazed how much weight these shelves hold.  I also built a "shed" in my driveway using these shelves as walls and 12' studs for as roof joists.  Zip ties hold the whole thing together.  I raised those shelves up by one level so I could walk under it.  So they have become  my go to construction material.   For the roof I used billboard vinyl from eBay.  It has stood up to a lot of winter storms.   The heavy stuff on the shelves keeps the shed from blowing away.
Offline sarel.wagner
  • Cooking up an Electronix Storm
« Reply #2780 on: July 08, 2017, 04:52:02 pm »
Hi, my lil corner of the World. Do all sorts of things in here. It is one of 5 different areas, the others are for metalworking, woodworking and restoring and building old cars and other hobbies.
Enjoy this forum tremendously, thank ya all.
Groetnis
Offline macboy
« Reply #2781 on: July 08, 2017, 07:13:02 pm »
Groetnis
Can I ask where you got that nice ruled cutting mat?
Offline CopperCone
  • *knock knock*
« Reply #2782 on: July 08, 2017, 07:28:58 pm »
wanger, what is that shallow cabinet you have? The grey plastic one.
Offline neo
  • The specialist.
« Reply #2783 on: July 08, 2017, 07:40:29 pm »
Between zip ties, duct tape and a little bit of creativity i have found most problems to vanish. This shelf is held to the wall with zip ties, it has surge protectors zip tied to it, the VU meter is zip tied in place and my function generator is zip tied to my oscilloscope because i got tired of it moving.  Actually i got it from Sutherlands, a hardware store, but nothing says it isn't just a re-branded cost co shelf.
« Reply #2784 on: July 08, 2017, 07:48:04 pm »
It an A3 cutting mat by Humbrol: https://www.humbrol.com/uk-en/shop/accessories/a3-cutting-mat.html
The desktop grey cabinet is an A4 paper filer of unknown origins, does not have a name and I got it second hand.
Rgrds
Offline trophosphere
« Reply #2785 on: July 08, 2017, 09:58:45 pm »
My updated lab bench after having moved to a new apartment last week (hence the clean desk and not wanting to hook up my 10MHz frequency standard distribution network). I will be moving again to an actual house in about a year so I am still sticking with the foldable desk until then. There are pieces of wood (2x4) which act as supports for the heavy equipment on the left side.
Offline tablatronix
« Reply #2786 on: July 08, 2017, 10:08:23 pm »
Might I ask where you obtained the blue covered parts bins from? They look like old floppy disk sorters. i have never come across shelf sorters with covers.
« Reply #2787 on: July 08, 2017, 10:25:45 pm »
They are called Akro-bins and I believe I got them from Amazon along with the lid accessory in a package of 6 units. They are nice to use for segregating ongoing projects.
The following users thanked this post: tablatronix
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #2788 on: July 09, 2017, 11:11:52 am »
Since now are holidays, I'm back in my hometown. Therefor I don't have a lot of stuff. Feels like starting the hobby all over again, working with scrap and using more or less shitty gear. Plus my lab here is split in two. One in the garage to do soldering and mechanical stuff plus stash for bulkier things and in the apartment, were I do programming and some small parts are stashed.
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
Offline hwj-d
  • save the children - chase the cabal
« Reply #2789 on: July 13, 2017, 06:08:46 am »
Hi all,
that's my little corner for feeling of happy satisfaction and enjoyment (or not).  ;D
After decades of being an application programmer and network admin i conquer here myself  my earlier hardware knowledge back and learn the new stuff from today.
The workbench is not emf ready. A lot of switching power supplies and wlan routers are hanging around under the table. That's very counterproductive to measure out something like voltage references or others, must think about it. But what we will do with a lot of pizerow's esp32's and other stuff like this...
But for now, i'm involved with modern opamp's, kx references and voltage dividers, output buffers and related protections, meaning to learn about them...  ^-^
Thanks all for the good stuff you put in here, and specially to dave&dave  :-+
(in hope, that ends up not too expensive to me...)
Offline jimdeane
« Reply #2790 on: July 13, 2017, 06:44:10 am »
I don't know if I've posted photos of my home or work(1) workbenches, but here's my current work(2) bench (attached):
Offline Dubbie
« Reply #2791 on: July 14, 2017, 12:19:49 am »
Whats going on up on that top shelf there?
Offline ez24
  • L.D.A.
« Reply #2792 on: July 14, 2017, 01:38:29 am »
The good dubbies.  I could not resist  :-DD
Offline JustSquareEnough
« Reply #2793 on: July 14, 2017, 02:26:04 am »
Hi all,
looks like a nice place to learn! what kind of desk lamp is that, i like it!
Offline hwj-d
« Reply #2794 on: July 14, 2017, 07:17:20 am »
Hi all,
Yes, learning and prototyping, in this order. ;)
The lamp is made quick and dirty with some aluprofiles, very cheap 10W led modules, a cheap 3A buck converter, silicon wires, an old laptop power supply and a sonoff module. But it needs a glass diffusor.  ;D
Offline djos
« Reply #2795 on: July 15, 2017, 07:21:39 am »
My work bench in the garage got a minor upgrade today, I installed a 300 x 400 mm shelf for my soldering / desoldering station - this just gives me that bit extra room on my work bench. Note I just need to get a proper anti static mat.
« Reply #2796 on: July 16, 2017, 12:18:27 am »
nicely done! thank you for the details
Offline jimdeane
« Reply #2797 on: July 19, 2017, 05:01:41 am »
Asking me? In my photo, the top shelf has four scintillator and photomultiplier muon detector assemblies.
Offline Dubbie
« Reply #2798 on: July 19, 2017, 11:08:43 am »
... the top shelf has four scintillator and photomultiplier muon detector assemblies.
Nice! What do you power them with? don't they need high voltage like most tubes?
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #2799 on: July 19, 2017, 11:24:16 am »
Are those assemblies selfmade ?
