Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2313375 times)
0 Members and 34 Guests are viewing this topic.
Offline phlegeton
    • spacebugs
« Reply #4125 on: January 09, 2020, 09:43:16 pm »
This is how my workbench looks like. Mostly I'm working on old digital stuff.
The following users thanked this post: Shock, edavid, Zucca, Kean, Mortymore, Atomillo
Offline andy3055
« Reply #4126 on: January 10, 2020, 01:13:23 am »
That is a crazy setup! You must have spent a fortune for that.
Online Mr.B
« Reply #4127 on: January 10, 2020, 02:32:53 am »
We I come from we call that a five-tune...
Offline phlegeton
    • spacebugs
« Reply #4128 on: January 10, 2020, 10:53:20 am »
Not all the equipment came cheap, but most of them I got cheap, as being "sold as is". and invested time to repair it. Since I do this as a hobby, and never studied electronics I learned a lot from repairing stuff.
Offline Jester
« Reply #4129 on: January 11, 2020, 05:38:19 pm »
Jester, very nice setup!  Before we moved to our present house my basement space had a lot of point source halogen lights much like yours.  I found I was always working in my own shadow - but then I didn't have as much task lighting as you do.  Do you find that too?
Completely agree on the point source lighting, it was here when we got here. The garage is the same way, I’m going to install an array of LED tubes on the garage ceiling, not sure what to do for my lab/shop area yet other than strategically placed gooseneck style lights.  Any suggestions?
Offline H.O
« Reply #4130 on: January 11, 2020, 10:35:18 pm »
Jester,
A drillpress, a lathe and a CNC mill in a room with carpet on the floor - how's that working out for you?  ::)
Seriously though, nice setup!
Offline mrjoda
  • Country: sk
« Reply #4131 on: January 12, 2020, 12:58:47 pm »
I've finished new workbench lamp - IKEA TERTIAL converted to old Vossloh-Schwabe industrial grade LED light, 33W, 3500K white. Finally a ton of light :)
« Last Edit: January 12, 2020, 01:01:18 pm by mrjoda »
Offline stefan_trekkie
  • Country: bg
« Reply #4132 on: January 12, 2020, 01:09:19 pm »
Small in comparison to yours but don't know when that will change.
Offline Jester
« Reply #4133 on: January 12, 2020, 02:16:18 pm »
Jester,
Only the office area is carpet and will likely be changed, the shop area is epoxy.
Offline stijn.lanszweert
« Reply #4134 on: January 19, 2020, 11:26:35 am »
My small work-bench @ home
910558-0
« Last Edit: January 19, 2020, 11:35:33 am by stijn.lanszweert »
Offline Falkra
« Reply #4135 on: January 19, 2020, 04:23:28 pm »
Nice, and I see you are using Pi-hole, which is very nice too.  ;) :-+
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #4136 on: January 20, 2020, 06:12:40 pm »
I have Pi-hole too, but it is installed on my Intel-based router, and somehow the Web interface is inaccessible.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #4137 on: January 21, 2020, 12:46:59 am »
Have you tried accessing it by typing http://<IP address>/admin/ ?
Depending on how things are setup, trying to access by typing http:/pi.hole/admin etc might not work.
Also, you did say yes to the option to install the web interface when you set it up? :)
Offline jogri
« Reply #4138 on: January 23, 2020, 03:01:49 pm »
So many benches, yet so few electric desks...
Offline Pinkus
« Reply #4139 on: January 23, 2020, 03:20:52 pm »
I often miss a height-adjustable worktable, but my concern is that it is not 100% stable and will wobble slightly. And this is something you can't use when assembling a board. But I have to admit that I have never had a closer look at such a height-adjustable table before.
Maybe someone can contribute with their own experience?
Offline jogri
« Reply #4140 on: January 23, 2020, 04:34:21 pm »
Mine is quite stable (more stable than my drawing table with L legs)  up to 90-95cm, you can do delicate work without a problem when sitting. It gets a lot more unstable over 100cm, but you can still write on it until approx. 120cm. I have mine at 125cm when i am standing, at this level every button that i press on my gear causes a noticeable wobble (maybe 2-3mm, definitely too much for smd work). It is rather nice when you are working on equipment that is too large/bulky to repair when sitting (big oscilloscopes/AVRs, etc) but too low to work on comfortably when you are standing.
Another thing to look out for is the max. load, most tables are rated for 60-70kg (not a lot if you have equipment on it). Mine is rated for 120kg, but judging from the sound of the motors at 70kg load i wouldn't recommend going over 80-90kg.
If you want to test such a desk in person, i'd recommend a trip to Ikea: Their electric desk is a bit on the wobbly side, but it should give you a fair impression of the stability of electric desks.
The following users thanked this post: Pinkus
Offline Teti
  • Country: cz
    • www.martenelectric.cz
« Reply #4141 on: January 29, 2020, 10:31:12 pm »
Humble beginnings maybe but there’s more going on in your picture than most of the benches posted in here  :-+
Yep - and a great view too!
Ha yeah, we've bough a house and finally I will have my own Man cave with EE Lab, Vingate Computers and Hifi. All is in a summer house in storage.
Vintage audio gear connoisseur, computer enthusiast, time-nut, music lover, vintage games gamer, nerd, tinkerer and shady electronic projects maker.
http://www.martenelectric.cz/
« Reply #4142 on: January 31, 2020, 10:16:32 am »
Not mine but the couple of gears left in the Brain Box are turning if not for benches then maybe a wall panel. Skip the legs but they are cool too.  :-+
Offline McBryce
« Reply #4143 on: January 31, 2020, 10:18:27 am »
Nice, but obviously made by someone who has never actually made a real PCB, otherwise they would have used more realistic footprints.
McBryce.
Offline Gary350z
« Reply #4144 on: March 31, 2020, 07:41:59 am »
No workbench pictures for two months. :(
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #4145 on: March 31, 2020, 08:07:09 am »
 :-//  You asked for it...  ...posted in our chat on Saturday - I started excavating (literally) mine the other day.  When I took the pic I'd cleaned enough for one cat to fit; at this point I think three of them could get onto it.  At least there's been a bit of progress...
-Pat
The following users thanked this post: edavid, pardo-bsso
« Reply #4146 on: March 31, 2020, 09:21:33 am »
While nothing major lately the arrangement of my benches is always in flux and this is how they appeared 5 minutes ago.
The following users thanked this post: edavid, bd139, ferdieCX, 6h8c
Offline ferdieCX
  • Country: uy
« Reply #4147 on: March 31, 2020, 02:14:32 pm »
Do I see a RCA scope from the middle 70's under the table ?
« Reply #4148 on: March 31, 2020, 03:05:50 pm »
Yep, good eye. An RCA WO-505A I restored last year.
Offline ferdieCX
  • Country: uy
« Reply #4149 on: March 31, 2020, 03:42:31 pm »
We had some WO-505 and WO-535 in the technical university when I was a student  ::)
