This is corner of my bedroom, it's nothing fancy nor professional, but it's enough to get yourself lost in the rabbit hole of electronics.
On first image is workbench, it's fairly small for my needs, i also use it for homework and studying, since i use it for more than electronics that place is always covered in mess and there is never enough space. On the right hand side of table i have DIY powersupply and Weller PU81.
On second image there is tool box, mostly hand tools, dremmel and some other accessories.
On third image there are multimeters, 80% of time i use Protek 506, on UT61E voltage, micro and mili amps aren't working, and i use it mostly for capacitance/resistance measurements, cynical Fuke DT9205 powers up but every range is out of spec and it is crap, i have it because i like having bunch of DMMs around, i feel professional and sophisticated.
I like calculators, and on forth picture there is Casio fx-991ES plus which i use in school, and HP48G is for my personal amusement.
5. 6. and 7th image is of my recent mod for workbench, i bought LED strip that was on discount, it's warm white 12V. Since i didn't have 12V adaptor, so i cut two stripes 80cm long and connected them in series so i can use 24V adaptor which i have. So in total those are two 80cm strips connected in series that are placed parallel to one another. 102 LEDs total, it gives bright light, but it's not blinding as the light i have had before (rotating lamp attached to desk). Light is even and it's ideal for technical drawing. I used some medical tape to tape up the cable to desk so it doesn't fall down and pull the stripes, it's only temporally untill i find transparent tape.
Future plans: definetly osciloscope, been looking for one atleast 7 months, prices of second hand scopes in Croatia are unbelievable. Hot air station might come soon, also looking for function generator.
Also i might build another bench so that it makes letter L with current bench, or if my budget gets low ill get rolling chart where i will have powersupply, function generator and osciloscope. I'm teen and i need more space (on the bench).
