Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2306665 times)
Offline Messtechniker
« Reply #3900 on: December 23, 2018, 09:36:04 pm »
Only one thing is annoying: The holder holds quite firmly onto the screwdriver (which normally is good of course!). So it might happen you lift everything up instead of taking out the screwdriver.
I always thought about adding some weight (piece of brass or whatever) to them, but never came to do it.
Or use this underneath:
Paste Hama 00007091 or Walimex 17368. Conrad has it. You my even find it in some supermarkets in the photography section.
It is kneadable, reusable, removable without residues. Photographers use it to hold small items in place. I use it all the time to prevent lightweight objects like scopes from being pushed back or to attach small temperature sensors to a wall, for example. The missus uses it instead of wax to attach candles. Because it does not solidify, it is easily possible to set up the candles strait even after some time.
Offline Inverted18650
    • Test Gear Addicts
« Reply #3901 on: December 24, 2018, 01:35:18 am »
Ah, it looked like yours was double row, but maybe you just have two?
I can get this from Amazon, and probably will after Christmas. I don't much like the green color, and it's a bit cheap looking also, but it'll probably be okay.
https://www.amazon.com/Wiha-Rack-6-Electronic-Tools-26000/dp/B0195UX8DG/
Would a 3D printed version of this work for you or are you after the OEM rack?
Offline rdl
« Reply #3902 on: December 24, 2018, 07:02:56 am »
This is how I store them now, which is not that bad really.
I think the green Wiha rack from Amazon will be fine. If it won't stay down when a driver is removed, I'll attach it to the pegboard or something. I might just do that anyway because I have this thing about not storing items on the table top.
Offline DL8RI
« Reply #3903 on: December 24, 2018, 10:33:40 am »
In my old lab, I had it also mounted on the wall.
Since the wall behind my desk now is just a dry-wall, I did not want to mount anything there. Therefore they are on the desk.
Thanks, I will test it.
Offline Urs42
« Reply #3904 on: December 24, 2018, 06:25:07 pm »
My "lab"  during the 35c3 setup
    • Test Gear Addicts
« Reply #3905 on: December 24, 2018, 10:43:27 pm »
I am going to mod and print a few of these:
https://www.thingiverse.com/thing:2405739
Offline eugenenine
« Reply #3906 on: December 25, 2018, 01:11:18 am »
I think Urs42 might be smaller than mine
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #3907 on: December 26, 2018, 06:33:56 am »
Guys, how among you have a robotics home lab? what assets and tools you think is needed?
Offline InductorbackEMF
  • Repair/Rebuilding.
« Reply #3908 on: December 30, 2018, 07:56:33 am »
Welp,i kinda feel a wee little bit out matched hehe.
We have a huge garage so why not right?
By the time i uploaded this i changed it setup again.(oops)
Alex.
Want a cup of TEA? (just one more meter please..)
Alex.
« Reply #3909 on: December 30, 2018, 08:13:37 am »
In reference to moving screwdriver holders above. Got mine sorted a while back with a quick design & 3D print which also keeps my precious Lindstroms from getting abused or dropped on the floor too. ** Not shown is the grotty bench full of crud under it  :-[
Offline Mr.B
« Reply #3910 on: December 30, 2018, 07:33:42 pm »
Love the octopus...
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
Offline Mr. Scram
  • Display aficionado
« Reply #3911 on: December 30, 2018, 08:01:07 pm »
Alex.
Outmatched? I'm fairly sure the vast majority of the forum can only dream of your kit.
Offline BFX
  • Country: sk
« Reply #3912 on: December 31, 2018, 04:12:39 pm »
Have a nice Silvester and Happy New Year  :-+  :popcorn:
Last state from lab in this year :) (little bit blurry but you know alcohol and let's fire up as much instruments as possible :D)
« Last Edit: December 31, 2018, 04:15:55 pm by BFX »
The following users thanked this post: edavid, Edison, BillB
Offline exor
« Reply #3913 on: December 31, 2018, 05:34:57 pm »
Temporary workplace to find out what is wrong with my friend’s RCF ART705AS subwoofer amplifier..
Offline Edison
  • Country: cz
« Reply #3914 on: December 31, 2018, 06:42:46 pm »
You want the light - "BFX"  ;D  here is   :-DD
Safety light, can not be overlooked
Repair of PIR sensors from the house corridor
Happy New Year
« Last Edit: December 31, 2018, 06:51:23 pm by Edison »
Everything works as the weakest link in the chain
Offline frozenfrogz
« Reply #3915 on: February 04, 2019, 03:26:38 pm »
Finally some updates on my workbench this weekend! :)
I added a top shelf at the back and also a bridge with slide rail in front to hang my Delvos.
Please excuse the craptacular photo "quality"!
Looking forward to getting my new Quick 861DE in the next week or so.
ToDo:
 - parts storage, especially SMD
 - add another fume extraction unit for SMD soldering - currently using fume extraction at the tip (Ersa ET7-1IP, actually an Ersa labled Bofa T1-1IP)
Offline PTR_1275
« Reply #3916 on: February 04, 2019, 03:53:00 pm »
Are they older model hios torque drivers hanging off the spring balances? I can’t quite make out the power supply unit.
Did you buy or build the plier / scredwider holder (wooden one, not the wera precision one)
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #3917 on: February 04, 2019, 04:35:22 pm »
What is that Anritsu (if it is?) with the metric shit-ton of BNCs in the front?
Online gamalot
  • Correct my English
    • Youtube
« Reply #3918 on: February 04, 2019, 05:13:47 pm »
Looks like a Anritsu MG3681A
Offline frozenfrogz
« Reply #3919 on: February 04, 2019, 11:13:54 pm »
Did you buy or build the plier / screwdriver holder (wooden one, not the wera precision one)
The torque drivers are DLV 7540-MKE with DLC 4510-JE supply and DLV 7331-CKG with DLC 1213-GG supply. Both with the 1/4'' hex bit receptacle instead of those 4 mm half-round / shank ones, because I already have a gazillion fitting bits. :) Bought both of these used on eBay a while ago, for 80 € and 55 € delivered. They seem well used and needed some cleaning, but other than that they work like a charm. No worn out bushings or bearings.
At around the same time I could score a lot of five NOS Hahn & Kolb Autostat 7212-01 balancers - basically for the price of one.
The tool holder for the pliers and screw drivers is made from routed plywood parts (6mm). They are around 10 € from some model making shop, but if you happen to have a CNC router or want to DIY cut some by hand with a scroll saw, just drop me a PM and I will send you a DXF.
Offline DDunfield
« Reply #3920 on: February 07, 2019, 01:41:23 pm »
Finally got around to tidying the lab to the point where it's not too embarrassing to take photos... Main workshop is still off-limits (project for spring!), but I did include a snap of the corner where I do smaller physical work and soldering.
Dave
Online Shock
« Reply #3921 on: February 07, 2019, 04:51:32 pm »
You have a nice amount of space there, my shelving system wants to move in.
Offline netdudeuk
« Reply #3922 on: February 07, 2019, 06:00:17 pm »
I was thinking the same thing.  Most Brits have to live in a space smaller than that  ;)
Offline hammy
« Reply #3923 on: February 08, 2019, 12:53:59 pm »
You got your ducks in a row! Well done!  ;)
Offline bsfeechannel
« Reply #3924 on: February 08, 2019, 01:52:24 pm »
Dave
Are those white, pink and blue boxes, ice cream containers?
