OK Cool.
Unforunately just had an accident. While waiting for my Amtech flux to arrive.
So far, had:
* Setup my MAX6675 thermocouple, and checked it's accuracy against ice water, boiling water, body temperature thermometer. Check.
* Checked the performances of my other irons:
ts-100, bc tip
350c = 240c
oled v3.1 'r1' cfw, knife K tip
350c = 250c
oled ve2.1s 'r2' blue,, knife K tip
350c = 250c
Those were the maximum steady state reading after some time 'settling'. 1-2 mins. So they all seem to have a 100c drop, between the internal temperature reading inside of the tip. Compared to what the k-type thermocouple was sensing across the molten blob of solder, and through it's protective metal tin can.
* It was not yet possible for me to measure or plot the power draw. But I do have 3 very large shunt resistors. 15A/75mV. That would have taken more time to setup.
* Started to make a chart, to measure the temperature fluctuations behaviour.
The next step was replace the op-amp. And also upgrading the step down voltage regulator that goes from 24v to 3.3v. To compare the smoothness / noise of the temperature fluctuations. Before and after. This way I can be confident to know it works. Not to have to guess what might cause any potential performance issue is in the software or hardware. Should that be the case.
Unfortunately as I finished my 1st chart, I put the handle into the holster. An had to bend down to unplug the PSU from the AC power socket on the floor. While my attention was diverted I missed what happened. But it seems to be that the MOSFET shorted out. And created a small fire on the back of the board.
Up until then I had been running the iron constantly at 350c for some minutes. To plot the chart. So I am unsure what the cause was. It could have been any one of these things:
* If I had run it too long. And the MOSFET got too hot over a long heating time.
* If something shorted internally inside of Handle. When I replaced the handle in the holster.
* If when i leaned down, it moved the PCB around on my desk, and shorted against either the thermocouple can (housing), or some little solder blobs. I don't know!
The mosfet was on fire for about 5-7 seconds. Images attached.
When my amtech flux comes, I shall remove the mosfet and nearby components. And see if the PCB is too damaged. Or can be repaired. Sorry to let you guys down and set things back. For testing the open firmware.
The other problem might be I don't have exactly the same mosfet to replace. But I do have a few other mosfets for other project(s). If they are compatible or not, IDK. Will have to check.
OR I could 'borrow' the mosfet from the other OLED v3.1 'r1' green PCB.
https://github.com/dreamcat4/t12-t245-controllers-docs/blob/master/controllers/stm32-t12-oled/v3.0-and-v3.1/r1/front-display-hw-sw-version.jpg Which is currently seems working OK / fine. That other controller was the one needing the 48 pin package F103. Which as we discussed was to take off from the Chinese "blue pill" clone board. Which is not genuine ST F103, but a chinese clone MCU.
I was trying to avoid it for now. Because you said yours had died. And I just didn't want to damage mine either. Since I only have 2 of those "blue pill" boards. And they are cool to have around for general use.
After I get my amtech flux I will post more images. To better see the damage underneath. And check what mosfets I have. Without having to wait to order replacement parts, which would delay things.
