Hello UniSoft, thank you so much for your great job for our Ridens!
Working with 1.37.1f on my RD6006 I have found one bug regarding the "SaveGraphSett" function: it works for the setting of voltage, current, temperature, but NOT for the wattage, as you can see below in the clip I just recorded:
As you can see, my graph setting for the Power curve was set to "OFF" (time 0:11). However, after rebooting, the setting goes itself to "0.01W" (time 0:20), so I need to set it again manually (time 0:25). It is very easy to reproduce this bug, since it occurs always for me (time 0:31 and later 1:02).
Would it be possible to correct this bug? I use pretty often the charging function, so it would be great, to have a patch here.
And the 2nd topic: I'm very happy with the "CutOff -ΔV/Δt" since even with the smallest setting 10 mV it works really reliable on my system when charging a single AA cell. From the manufacturer of the cells (Panasonic) I know, the optimal threshold is 7,5 mV per single cell, but of course I know the Riden's hardware does not have that good resolution, so we need to take 10 mV (setting 0.01 V) which is still pretty good, as I tested it on more than 20 cells.
UniSoft, would it be possible to add an adjustable time delay before arming the "CutOff -ΔV/Δt"? I know in the current firmware this value is hard-set to 5 minutes, so the the cutoff is "armed" after the first 5 minutes. My problem is, some of my cells need up to 40 minutes for the voltage rise. This means, the voltage goes down for the first 40 minutes since cells are getting warmer. This triggers the CutOff far to early for me. My solution is to deactivate "CutOff -ΔV/Δt" for the first 20-40 minutes and after I see on the graph, the voltage rises, I activate CutOff manually. Finally the voltage drops again and "CutOff -ΔV/Δt" terminates the charging. But, as I said, this is a manual process. If I only could postpone the arming of "CutOff -ΔV/Δt" by 30 minutes, this could work really autonomously. Since the time delay may be cell-specific I think the adjustable time delay would be the best for all of us. With the default value of 5 minutes it would be exactly the same as it is now. But having it adjustable would help for some older cells that some users have.
