Author Topic: $20 LCR ESR Transistor checker project  (Read 3470340 times)
jellytot, moimem and 26 Guests are viewing this topic.
Offline Obelix2007
Offline mojoe
« Reply #9026 on: January 14, 2024, 02:22:35 am »
I have an old MK-328 that I bought several years ago. I think I flashed it back then, as when it powers on, it says "GM328" and the "Show Data" menu reports firmware "1.14k".
Attached is a picture of the front of the case (from the net, but mine is exactly the same). Also, a picture of the PCB (again from the net).
It has a real 328P with an 8 MHz crystal. In the upper left corner are several unpopulated pads. Near the center are missing C9, U2, D2 & L1.
Can anyone tell me what the missing components are for? I assume that some may be for zener testing. Is there a full schematic, showing the missing components? Is it worth the trouble adding a rotary encoder and other missing features?
If I hold down the power button, I get a menu with several choices. Short presses cycle through them, and a long press selects one.
Online coromonadalix
« Reply #9027 on: January 14, 2024, 02:59:17 am »
mmm maybe was for a rechargeable battery ??  you have diodes and a inductor ...  and the 2 diodes seems to protect against an inverted supply
r22  would be some limiting resistor or can or could blow if over current ?
you would need to dismantle it and try to make a schematic
many teardowns on the web show no populated parts .....
« Last Edit: January 14, 2024, 03:12:05 am by coromonadalix »
Offline madires
« Reply #9028 on: January 14, 2024, 09:53:10 am »
Looks like a signal input stage for the frequency counter. A rotary encoder helps with menu functions. And the firmware is a modified k-firmware (the latest k-firmware is 1.13k). If you like to update please see https://github.com/kubi48/TransistorTester-source/tree/master/trunk/mega328_MK-328,
The following users thanked this post: mojoe
Offline indman
  • Country: by
« Reply #9029 on: January 14, 2024, 02:25:06 pm »
U2 is the place to install the same +5V stabilizer as U6, just a slightly smaller form factor.
C9 is an additional capacitor for filtering the +5V output voltage. In some MK-328 models, 47μFx16V is installed in this place. L1 is an inductance for additional filtering of the input voltage to the stabilizer U6 (instead, jumper R14 is now installed). D2 is a protective diode. In general, these additional elements are not needed for this circuit, since it works stably without them.
Connector J5 and the circuit for it are an input signal bufer -  for the frequency counter option (as dear madires answered correctly).
« Last Edit: January 14, 2024, 04:22:22 pm by indman »
Offline Per Hansson
« Reply #9030 on: January 14, 2024, 06:16:14 pm »
Hi, I'm looking for this kind of tester. I've checked the PDF (https://github.com/madires/Transistortester-Warehouse/blob/master/Documentation/English/Clone-Comparison-Chart.pdf) that lists all the clones and it looks like the Hiland M644 is a decent option. But the PDF is a few years old and I can't find this particular model anywhere on eBay or Aliexpress.
I liked that it can test Zener diodes above 5V and would have liked it to have external power too.
Are there updated recommendations? If not, what happened to this model and where to find it?
Cheers!
... https://de-m.banggood.com/Original-Hiland-M644-Transistor-Tester-LCR-Diode-Transistor-Zener-Quartz-Measurement-p-1279042.html
Greeting Horst
Just adding my $0.02 opinion: the Hiland M644 is not worth $40
It has quite a few design mistakes that reduce the accuracy and usefulness of the device.
But on this note I wonder if any nice DIY projects exists to make a tester based on the Atmega 644 or 1284 chip that still stays true to the original intent of keeping this a simple low cost device?
On the previous page a very advanced SMD version was shown but I'd be more interested in a cut down version.
Maybe the PCB could be designed to both accept through hole and SMD components (or two separate PCB designs).
So far the closest designs I've found are these but I don't know if they have been published?
https://www.eevblog.com/forum/testgear/show-us-your-$20-transistor-tester-enclosures-and-mods/msg1201483/#msg1201483
https://www.eevblog.com/forum/testgear/show-us-your-$20-transistor-tester-enclosures-and-mods/msg4851821/#msg4851821
A cursory Google search also brought up this design, but I could not find the original author of it:
https://oshwlab.com/amilio.spring/ESR-Atmega-644
I think it would be nice if someone competent in PCB design would make a project on Github to make the hardware as accessible as the software is.
I could try myself but I'd probably make the same kind of mistakes that the original Hiland M644 design has as I'm not a PCB designer by trade...
« Last Edit: January 14, 2024, 06:53:59 pm by Per Hansson »
Offline madires
« Reply #9031 on: January 14, 2024, 06:47:04 pm »
The following users thanked this post: Per Hansson
Offline Per Hansson
« Reply #9032 on: January 14, 2024, 07:37:44 pm »
Thanks madires! Is the display PCB also available?
I just found a post by snapper on the German forum where he made an updated version of the Hiland M644 PCB.
I'm not sure if he published it anywhere though?
Relevant posts:
https://www.mikrocontroller.net/topic/transistortester-avr?page=32#7511818
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg4886483/#msg4886483
« Last Edit: January 14, 2024, 08:21:50 pm by Per Hansson »
The following users thanked this post: coromonadalix
« Reply #9033 on: January 14, 2024, 07:49:25 pm »
same for a mega 2560 ... nothing so far  ...  but code is there ...
Offline madires
« Reply #9034 on: January 14, 2024, 08:56:42 pm »
No, it's just a 3.3V LDO and level shifters (74HC4050, 74HCT125).
AFAIK, he didn't publish the PCB. However, you could ask him for a copy.
Offline madires
« Reply #9035 on: January 14, 2024, 09:01:20 pm »
I'm using an Arduino Mega 2560 clone for testing, especially for displays with an 8-bit parallel bus.
Offline Bibbbi
« Reply #9036 on: January 18, 2024, 11:47:24 am »
Has anyone successfully managed to compile the madires Transistor project via the IDE Platform VSCode/PlatformIO instead of using the old WinAVR environment?
How does it work?  :-//
Offline jdev99
« Reply #9037 on: January 20, 2024, 06:34:47 pm »
I tried your settings with a 16MHz ATmega644 tester but couldn't reproduce what you've seen. Also after running the RCL monitor a 1µF cap measured fine for all probe combinations.
Can you use the ATmega644 with a 16MHz crystal?
I tried it and it does not work. If I look at the fuse settings for oscillators, it only goes to 8Mhz.
What am I missing?
Offline madires
« Reply #9038 on: January 21, 2024, 11:19:24 am »
Yes, a 16 MHz crystal works fine. The fuse bits are the same as for an 8 MHz quartz (external crystal, 1:1 prescaler). But you need to compile the firmware for 16 MHz (-> Makefile).
The following users thanked this post: jdev99
Offline jdev99
« Reply #9039 on: January 21, 2024, 05:57:36 pm »
I now installed a ATmega644 + 16MHz crystal, and it works great.
The only other thing I want to know is how to improve the zener test values.
A 5.1v read as 5.44v and a 12v read as 13.5v.
Offline madires
« Reply #9040 on: January 21, 2024, 06:42:18 pm »
Could be the test current (too low). Low wattage zeners need about 3 - 5 mA.
Offline jdev99
« Reply #9041 on: January 21, 2024, 10:29:21 pm »
It draws 3.7mA for the 5.1v, so it seems like there is enough current.  ???
Offline indman
  • Country: by
« Reply #9042 on: January 22, 2024, 07:44:48 am »
jdev99
A competent and simple solution, as indicated in the screenshot. Selection of the most optimal current and its stabilization for safe testing of high-power and middle(low)power zener diodes.
For more precise adjustment of the measured voltage on the zener diode, in k-firmware the Makefile contains lines for the input resistor divider
# Voltage divider for the external zener voltage measurement 180k / 20k = 10/1
CFLAGS += -DEXT_NUMERATOR=10
CFLAGS += -DEXT_DENOMINATOR=1
Instead of a decimal value, you can use the following numbers for smoother voltage adjustment
CFLAGS += -DEXT_NUMERATOR=100
CFLAGS += -DEXT_DENOMINATOR=10
In your case, to reduce the voltage, you can, for example, try the following values
CFLAGS += -DEXT_NUMERATOR=120
For m-firmware, similar divider settings are in the config.h file
#define ZENER_DIVIDER_CUSTOM
#define ZENER_R1         180000
#define ZENER_R2         20000
« Last Edit: January 22, 2024, 07:55:13 am by indman »
Offline rherber1
« Reply #9043 on: January 22, 2024, 09:42:50 am »
I have purchased an LCR-TC2 which appears identical to that in Swainster's pics(Reply #8574 on: May 09, 2023, 05:00:09 am). My pcb is marked T7-PLUS V2.0 also and f/w is V3.1E.
My tester exhibits odd behaviour when measuring resistors of 15 Ohms and 18 Ohms in that it identifies them as Inductors with some arbitrary value of inductance and with the nominal resistance shown. If I use 12 Ohms or 22 Ohms these values are correctly identified as Resistor with the nominal values displayed.
The ability of this tester to produce an accurate value of resistance appears to be quite poor. I measured a nominal 56KOhm resistor with two different multimeters and both produce a reading of 56k6 Ohms. The TC2 produces a value of 58k07 - not what you would call close to the result of both multimeters.
« Last Edit: January 22, 2024, 10:00:54 am by rherber1 »
Online wasedadoc
« Reply #9044 on: January 22, 2024, 10:36:07 am »
No, the effect would be the opposite.  Low current through a zener gives a lower voltage across it, not higher.
The following users thanked this post: madires, jdev99
Offline indman
  • Country: by
« Reply #9045 on: January 22, 2024, 11:26:50 am »
The Zener stabilization voltage may differ from the rated voltage even with the current allowed for it. Therefore, to be sure that the readings are correct, you must first provide current from the stabilized power supply through the zener diode, which is indicated in the datasheet for it, and then measure the voltage drop with a multimeter. This will be the right choice.
Offline madires
« Reply #9046 on: January 22, 2024, 11:50:14 am »
Have you run the self-adjustment (shorting all three probe pins)? BTW, that TC2's MCU is an LGT8F328.
Offline rherber1
« Reply #9047 on: January 22, 2024, 01:09:29 pm »
That procedure is not mentioned anywhere in the instruction pamphlet - so, no, I didn't do it.
Have done it now shorting 1-2-3 together and running a test. Shows 0.11 Ohms 1-2 and 0.14 Ohms 2-3. Then ran a test on the 15 Ohm resistor again and no difference - still says it is an inductor.
Offline madires
« Reply #9048 on: January 22, 2024, 02:20:17 pm »
Bummer! Unfortunately some of the tester clones with an alternative MCU come without the self-adjustment feature.
Offline csuhi17
  • Country: hu
« Reply #9049 on: January 22, 2024, 02:26:35 pm »
https://youtu.be/KPdoprtrfBg?si=xw6ZLrNqGqUZCcVY&t=130
Did the calibration go well for you, like in the video?
It happened to me that the calibration failed, because the resistance value was higher with the short between me.
After pressing Test, it showed two or three resistances between the test points.
