It’d certainly be trivial for the manufacturers to make an AC-powered dummy battery, akin to what’s common in cameras.That PSU most likely will be more expensive than AC powered tool, and likely oversized quite a bit to have enough power. I doubt you want something like 0.5-1.5kW PSU attached to the tool. Somewhat reasonable only for low power tools.I suggested looking to the ones on cameras: the actual SMPS doesn’t fit into the battery compartment, so the power brick is connected via a cable so that the camera stays compact (= existing accessories will still fit).
The problem is that high current surges aren't a problem for batteries but a power supply typically doesn't like them. So you'd need a huge PSU to replaces the batteries of a cordless drill (for example). Somebody I know has experimented with this and his results wheren't stellar. If you want a corded power tool, buy a corded power tool.
Yep. And while efficiency per se is not that much different as you pointed out, a brushed motor will by design wear out much faster. When it does, either you feel like renovating the motor by changing the brushes yourself (as long as you can find the parts), or you throw it away as finding the motor itself as a spare part is even less likely. Brushless motors have much, much longer lifetime.
Not all brushed motors wear up quickly, it's again a design decision. Larger brush area not only increase efficiency by decreasing current density, but slows down the wear. High-quality brushed motor power tools easily lasted years of daily professional use while cheap ones fail in worst cases in just few hours. Similarly, some brushed EV traction motors were good for easily 150 000 kilometers before brush swaps.
The snag is people want their hand held power tools to be hand sized.
I think motor life on battery powered power tools isn't that important as batteries replacement cost is the real cost. By the time the motor goes bad it's about time to buy another tool. The price of the tool+battery isn't all that much different from the battery alone.
It's a new one on me as I only heard it 'in passing' last week or the week before and I don't have any firm references yet (it's on the 'must look into' list) which is why I wrote 'some suggestion' rather than asserting it as fact.
*added*: I listen to a lot of 'stuff' whilst working, driving etc. for background noise, it might have been the latest Ham Radio Workbench podcast (hardly an authorative source on EU regs) with W1REX
nor putting an USB-C to an EV
Quotenor putting an USB-C to an EV
What? I won't be able to charge the EV from my phone's wallwart? What is the point of it all, then
I prefer having the smarts in the charger too.
Plus, it makes chargers more versatile for different devices.
But it seems like the industry is moving towards USB-C for uniformity.
Think about the possibilities - at 200W USB-C quick charge, during 12 hours of overnight charge, you could get 15 km of driving range in your EV. All you need to do is to apply a bit of extra engineering bypassing the car's existing power-hungry always-on-during-charge systems like unnecessary computers, poorly designed BMS and whatever, so that you can put most of that 200W (minus the main contactor) to do actual work. Then you just need to design an isolated, say flyback converter from 20V to battery voltage (400V-ish). Easy-peasy!
Somewhat more useful would be the capability to charge the 12V battery from USB-C.
