As the title, is here a reasonably quiet electric compressor, at a reasonable price, that has the same concentrated blast of air that an aerosol air can provides?
https://www.ebay.co.uk/itm/241184-ORAZIO-Low-Noise-Oilless-Silent-24L-Air-Compressor-750W-Garage-Clinic/282084042569?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
Or if you want something more general purpose, these are popular, but I don't know if there's a 220V version:
California Air Tools 2010A Ultra Quiet and Oil-Free 1.0 HP 2.0-Gallon Aluminum Tank Air Compressor
https://www.amazon.com/dp/B00TDNKBMC
Yes, there are a number of products intended for just that, such as:
220V Metro DataVac ED500 ESD Safe Electric Duster - Model ED-500-ESD
https://www.amazon.com/220V-DataVac-ESD-Electric-Duster/dp/B07BY71D4Y
If you search Youtube for California Air Tools, you'll find lots of 'Wow, is it ever quiet' videos.
For anyone in North America, California Air Tools products are available at or through Home Depot.
Ed
Ed
You really have to figure out what you mean by quiet.
Big-box retailer compressors are amazingly noisy. In comparison, the better oil-less compressors like the above mentioned California Air Tools are much quieter (down to about 56dB).
Whether that's quiet enough depends on your subjective evaluation. 56dB is certainly not "silent" by any stretch of imagination.
For low noise, nothing touches the oiled compressors, which are generally similar to fridge compressors, except filled with air. You get down do some really quiet models like the Silentaire 20A at 30dB. That's still not really silent, but it's definitely quiet. The 1/2hp Silentaire models at 40dB is where my personal limit is for indoor use.
Silentaire is Italian, but now own by a US company. In Europe, similar models are made by Bambi (UK) or Jun Air.
All of these are pricey are are best bought used from EBay (they are used in a variety of businesses like dentist offices, and, since they are oiled, will last forever if properly maintained).
MM Clarke compressors are good for the money but entry level your looking at £300, the cheapie airbrush compressor are reasonably quite
eg.
https://www.everythingairbrush.com/compressors/ab-as196-twin-cylinder-mini-piston-type-on-demand-compressor-with-receiver-and-dual-switch-for-airbrushing.html <<<<< can be found cheaper
Air brush compressors are quite, but small. That’s why I went with the aluminum 2 gallon tank, smaller then that and the compressor will be running continuously to attempt to deliver air. You can run up to a small nail gun with the CAT style compressor. Most people buy compressors based on the amount of air PSI they calculate their air tools require. I’m just using mine to blow relatively CLEAN air.
Your starting around the £300 with the bambi and most other silent
Your starting around the £300 with the bambi and most other silent, I don't know if the op has that sort of budget, there use to be a company in kent (uk) that sold its own refurbs (usually medical grade compressors)
A nice affordable, fairly quiet (be sure to install the muffler provided with it) and small (only 2.5cfm) compressor that I am very happy with is the
https://www.amazon.com/Rolair-JC10-Plus-Oil-Less-Compressor/dp/B0058NRVMO
Only 60dB
I have mine setup on a wire rack shelf (in a garage), so I may easily clean the floor with a garden hose and a mop. It is next to a MIG welder.
It is quiet enough that the vibration of the wire spool in the mig welder on the bobbin is louder then the compressor. The compressor just sounds kinda farty. The compressor has rubber feet but the wire shelf that it is on is fairly shitty so it flexes and vibrates.
I need to put some kind of tensioning in the welder to stop the wires from rattling around.
Perhaps I will put a plank of rubber coated wood under the compressor to see if I can isolate it from the welder (I think the vibration is traveling through very specific elements under the compressor feet, it might stop if its spread to all of them evenly.
