Author Topic: $20 LCR ESR Transistor checker project  (Read 3452898 times)
Obelix2007 and 14 Guests are viewing this topic.
Offline stj
« Reply #2400 on: August 16, 2016, 06:12:37 am »
ST7565
there is no ST7585
Offline roli_bark
« Reply #2401 on: August 16, 2016, 08:51:28 am »
Offline mauroh
    • Mauro Pintus
« Reply #2402 on: August 16, 2016, 09:47:12 am »
Is it just a typo in my message, I will correct it. The ST7565 is the correct display for the BGDIY M12864.
My list is correct, but it actually refer to the 1.22m version.
For the 1.23m 1.24m you need to modify also the config_328.h where the LCD section is located now
Mauro
Offline roli_bark
« Reply #2403 on: August 16, 2016, 05:32:04 pm »
FYI - for the 'banggood' version, the LCD display part # is JLX12864G-378
For whoever wants the datasheet - the manufacture (JLX) site:
http://jlxlcd.cn/china/productshow.asp?nClass=97&PClass=0&ID=280
(bottom of page)
JLX12864G-378-PC (with Chinese character library)
JLX12864G-378-PN (without Chinese character library)
HW Timing & Code examples included.
The following users thanked this post: jct
Offline Harm2k16
« Reply #2404 on: August 16, 2016, 07:14:25 pm »
stj, thank you again! :)
I'll go on experimenting with this.
TY
Offline flywheelz
« Reply #2405 on: August 18, 2016, 09:35:25 pm »
Please, I need help.
I have put together this kit from http://www.aliexpress.com/item/2016-DIY-kits-TFT-LCD-M328-Transistor-Tester-LCR-Diode-Capacitance-ESR-voltage-meter-PWM-Square/32649811953.html?spm=2114.13010608.0.93.OBbTox  I had to solder the three protection smd parts myself.  Kit does not include test capacitor.
With 9v batt plugged in DC jack and encoder pressed down, there is 235mA draw from batt.  The T3 labeled 9012 gets hot  :-//.  0 volts on socket pin 7.  In circuit the 9012 and two 9014 transistors test good.  The 5v reg 7550A-1 shows shows some voltage drops on every pin in both ways.
I have dis-soldered the LED and surge suppressor but no help.
Any ideas?
Update:
Thanks to stj for pointing it out, I soldered the SRV05-05 front to back.  Once removed device worked!
« Last Edit: August 20, 2016, 07:14:09 pm by flywheelz »
The following users thanked this post: alte
Offline tom666
  • Country: sk
« Reply #2406 on: August 18, 2016, 10:53:02 pm »
@flywheelz:
This is probably caused by a short circuit at the output of the 7550. This may be a short circuit on the PCB, defective capacitor or damaged the 5V stabilizer.
Offline flywheelz
« Reply #2407 on: August 18, 2016, 11:04:58 pm »
I've pulled the 7550 and connected in directly to 9v bat and it puts out 5.05 volts.  Also, without 7550 the 9012 is runs cool and switches on providing 9v to VIN for 7550.
Where is 5V stabilizer?  I don't have schematic from seller but looking at ttester.pdf page 10.
Thank you!
Offline stj
« Reply #2408 on: August 18, 2016, 11:30:57 pm »
did you test it with no atmel or display?
btw, i see you damaged the atmel socket! - i would have used a turned-pin type.
The following users thanked this post: flywheelz
Offline flywheelz
« Reply #2409 on: August 19, 2016, 12:07:34 am »
No atmel or display testing for 5v on pin 7 first.
Yes one pin 22 was violated by dvm probe, I will bend it back with a needle  :-+  But the LED wasn't so lucky, ended up with one leg  :scared:
« Last Edit: August 19, 2016, 12:16:28 am by flywheelz »
Offline stj
« Reply #2410 on: August 19, 2016, 12:56:07 am »
first, check the resistance between ground and the input and output pins of the regulator - to see which side the mystery load is on.
Offline stj
« Reply #2411 on: August 19, 2016, 12:58:12 am »
and make sure the 6pin diode-pack is on the right way!
Offline flywheelz
« Reply #2412 on: August 19, 2016, 05:10:02 am »
With 7550 removed - GND to Vout 20k ohms; GND to Vin 13.29k ohms.
I can't make out any writings on 6 pin turd.  On the pcb I saw a white dot, I took it as pin 1 and on one side of the brick there is a small tab sticking out, I took it as pin 1.
Is it on backwards?
Offline flywheelz
« Reply #2413 on: August 19, 2016, 05:38:20 am »
@stj, I think you nailed it.  I can barely make out scratched "| VO5" with one eye and tongue at a right angle and that would mean I put it front to back.  I will have more time Fri evening and will try to remove the diodes pack and put 5v reg back.
Offline stj
« Reply #2414 on: August 19, 2016, 06:17:36 am »
all the kits i have seen, the SMD stuff was already fitted.
was yours different?
Offline tom666
  • Country: sk
« Reply #2415 on: August 19, 2016, 06:34:22 am »
Schematic from seller:
Offline flywheelz
« Reply #2416 on: August 19, 2016, 03:04:12 pm »
@stj, yes,  my kit came with smd parts unpopulated.  Link to seller and picture of what I got few posts back.
@tom, thank you. It matches except for my kit has no input reverse protection diode.
Offline flywheelz
« Reply #2417 on: August 19, 2016, 03:28:18 pm »
Does it matter which way I place the suppressor AK1521 diode? I remember flipping a coin when putting it on due to lack of markings.
Offline vinceroger
« Reply #2418 on: August 19, 2016, 04:17:17 pm »
in stj post 6 post up theres a good picture you can zoom in on it looks like the part may have a white line/band on that goes towards the top of the tester
Offline flywheelz
« Reply #2419 on: August 20, 2016, 12:06:27 am »
We've made some progress!
The short was caused by the 6-pin diodes chip I've soldered incorrectly.  Once I removed it the tester is showing some life.  Thank you stj for pointing that out.
If I press in encoder for a second, the screen flashes white.
If I press and hold encoder, I see in green text:
  • Selection:
  • Switch Off
  • >Transistor
  • Frequency
Then it goes to:
  • Bat. 8.7V OK
  • VCC=5.04V
Then:
  • Bat. 8.7V OK
  • Vext=0mV
When I let go, unit turns off.
What now??? :-//  Its like something atmel not latching something to run.
Do the MC5 6-pin chip and AK1521 suppressor required to run?
I made sure pin 22 I damage is ok.  But looking the board, pin 22 is not connected to GND as schematic shows.
Update:
Other thing its missing is the LED and that looks like its required for the current path for s9014.  Is it correct?
« Last Edit: August 20, 2016, 12:13:41 am by flywheelz »
Offline stj
« Reply #2420 on: August 20, 2016, 01:01:26 am »
look at the schematic, there is a transistor or 2 that hold the power on.
and you DO need the led - it's not just for lighting up.
no led will cause this.
« Last Edit: August 20, 2016, 01:03:09 am by stj »
Offline flywheelz
« Reply #2421 on: August 20, 2016, 01:22:01 am »
I don't have any LEDs at the moment.  So I've soldered in a 3.3v zener the normal way instead of LED and now the unit stays on  :phew:  I think the original led had was1.8v forward voltage drop.  Do I need exact LED as original?
Offline GBowes
« Reply #2422 on: August 20, 2016, 01:52:04 am »
@stj: Good call on that TVS diode orientation.
@flywheelz: The LED is not critical. You could even leave the zener in but as the Vf is only about 0.65V, your current through that path will be higher (about 3-5 mA). I would suggest putting in any 3mm or 5mm red, wht, green LED. It is nice to have an indication that the device is on although it should power off after a timeout and you can also see the display.
Graham
Offline flywheelz
« Reply #2423 on: August 20, 2016, 02:21:11 am »
Graham
I think the zener might be causing a problem.  The button is not registering after power-up.  I can't enter calib.
Offline stj
« Reply #2424 on: August 20, 2016, 03:23:33 am »
dont you have anything in the junk pile with an led?
smd would be nice - it wouldnt be sticking up so much.
i do like smd led's :)
