Author Topic: $20 LCR ESR Transistor checker project  (Read 3452605 times)
carrascoso and 10 Guests are viewing this topic.
Offline Szybkijanek
« Reply #6575 on: October 23, 2020, 03:08:40 pm »
I haven't any hardware jumper. I guess. I just set software prescaler 1:16 (tip in file "Clones"), tester have soldered 8MHz crystal to ATMega.
« Last Edit: October 23, 2020, 03:14:26 pm by Szybkijanek »
Offline madires
« Reply #6576 on: October 23, 2020, 07:45:12 pm »
So problem is when put 7-9MHz and 15-17MHz HF crystal, tester show wrong value (300-800kHz) and when put osc. probe directly to crystal during the measurement scope show correctly value. There is something with the wrong reading. Can anyone check it? Max read freq on BNC mode is 1MHz?
The next step is to check the output fed into PB0 / T0.
Offline Dumidan
« Reply #6577 on: October 25, 2020, 11:29:19 am »
Please detail a bit what hardware version you have? Is it bought ready assembled? Is it made by you? If so, what scheme?
I know that when you ask for help on a forum, as an unwritten rule you have to give details about the problem, details of what you tried and what you got. No offense, yes?
Offline Ricky25
« Reply #6578 on: October 30, 2020, 03:38:03 am »
Hello friends,
i have (tried) to read up the thread (searched, checked indman Table of clones, ...) , but still cant find what is the best LCR to buy at this moment (or link to aliexpress) with support the firmware updates posted here.
Looks like i have to spend a little bit more time, but advice what to buy would be really helpful.
I did come as far as this  ::) : TC-T7-H
https://www.aliexpress.com/item/4001208715581.html
Thx
R.
« Last Edit: October 30, 2020, 03:59:41 am by Ricky25 »
Offline madires
« Reply #6579 on: October 30, 2020, 09:54:42 am »
Do you need an LCR meter and/or a component tester?
The following users thanked this post: Ricky25
Offline Ricky25
« Reply #6580 on: October 30, 2020, 10:46:51 am »
I would like to have a component tester (LCR functionality would be nice to have too :) ). They have today 20% for everything sold on AliExpress, would order one today.
I have read here a lot of comments about T1 / T7 and Bside ESR02 Pro, but could not read/figure out an "advice" for what to buy (with m/k firmware support).
R.
Offline madires
« Reply #6581 on: October 30, 2020, 03:41:04 pm »
The problem with recommending a specific clone is that there isn't any perfect or all-in-one tester. It's always a trade-off. The TC-1/T7 has the nasty U4 (a small MCU controlling power and test button) which needs to be reprogrammed or replaced with a small circuit. The Bside ESR02 Pro has only basic features. The Hiland M644 comes with the extended frequency counter, but no case and no LiPo. And there's the AY-AT (GM328A) which is still a good choice if you don't need a nice case.
Online indman
  • Country: by
« Reply #6582 on: October 30, 2020, 04:40:38 pm »
Hello friends,
i have (tried) to read up the thread (searched, checked indman Table of clones, ...) , but still cant find what is the best LCR to buy at this moment (or link to aliexpress) with support the firmware updates posted Thx
I believe that since we have 2 respected authors of the project and 2 firmware versions, it will be reasonable to purchase several devices from Chinese friends that will complement each other. Considering the very low price at present, which essentially amounts to the price of component parts, this will be a small investment that will quickly pay off. :D
« Last Edit: October 30, 2020, 04:52:12 pm by indman »
Offline Maniaxx
  • sys2064
« Reply #6583 on: October 30, 2020, 06:03:33 pm »
There are cases for the GM328A.
https://www.aliexpress.com/item/33036516954.html
Or are they that bad not worth to mention?
And yes, that's my favorite as it has color display and (in my opinion) the best h/w layout (more connectors for freq in/out, 9V plug, no LiPo (unnecessarily dangerous)).
« Last Edit: October 30, 2020, 06:19:22 pm by Maniaxx »
Offline Ricky25
« Reply #6584 on: October 30, 2020, 07:17:34 pm »
Thank you very much for your answers, i would start with a TC-T7-H :) .
Can i use the K/M firmware updates on that device?
Thx
R.
Online indman
  • Country: by
« Reply #6585 on: October 30, 2020, 07:52:17 pm »
Ricky25
Read my message carefully here https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg2910034/#msg2910034
TC-T7H will most likely be equipped with a 128x128 display with an unknown controller. Therefore, the firmware update on this clone will not be possible until the controller type is recognized. Clones TC-1 are most preferred for buying and updating the firmware.
« Last Edit: October 30, 2020, 07:54:17 pm by indman »
Offline eti
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« Reply #6586 on: November 02, 2020, 06:13:03 pm »
I need to know (not guesses please):
Can this LCR-T4 tester output logging via UART, and how would this be accomplished, please?
Thanks.
Offline madires
« Reply #6587 on: November 02, 2020, 06:36:43 pm »
Yep:
- find an unused I/O pin
- add a pull-up resistor to the pin (many TTL-serial2USB adapters will also work fine without the pull-up)
- compile k or m-firmware with the software UART enabled (set pin and features)
The following users thanked this post: eti
Offline eti
« Reply #6588 on: November 02, 2020, 07:33:06 pm »
Yep:
Trawling through the "Make" file and the others, put my mind in a spin... not sure which bits to flip, which code to change etc...  :-\
Offline madires
« Reply #6589 on: November 02, 2020, 07:35:20 pm »
k or m-firmware?
Offline eti
« Reply #6590 on: November 02, 2020, 08:13:34 pm »
Offline madires
« Reply #6591 on: November 02, 2020, 08:25:31 pm »
So you're running the modified firmware which came with the T4?
Offline eti
« Reply #6592 on: November 02, 2020, 08:31:27 pm »
Yes
Offline madires
« Reply #6593 on: November 02, 2020, 08:36:52 pm »
For serial output you need to choose between k and m-firmware. Are you familiar with compiling software and programming ATmegas?
Offline eti
« Reply #6594 on: November 02, 2020, 08:51:25 pm »
I know what commands to run, I can compile, yes, I just got thrown by all the serial options. As for what firmware I need, I found this in my email...
"TransistorTester 328p_st7565 1_13k r713"
Offline madires
« Reply #6595 on: November 02, 2020, 09:10:56 pm »
That's the k-firmware which uses PC3 as serial output. Edit the Makefile and uncomment "CFLAGS += -DWITH_UART".
Offline eti
« Reply #6596 on: November 02, 2020, 09:45:36 pm »
Thanks so much! I now have serial data coming out into "minicom", via my Bus Pirate (in "transparent UART" mode) @ 9600Kbps!
« Last Edit: November 03, 2020, 04:09:34 am by eti »
Offline eti
« Reply #6597 on: November 03, 2020, 08:07:37 pm »
I have two of these component testers:
#1: The one my UART enquiry was about (ST7565 LCD - gorgeous green screen)
#2: A "Fish8840" type tester, colour LCD, in a black case
On tester #2 (Fish8840), the ". . ." when it's testing the component is animated with growing periods ("."     ". ."   ". . ." etc) and also animates over serial. On tester #2, it is a static ". . ." symbol, which is fine on the LCD, but shows a non-printing characted over serial (attached). Any ideas how I can animate the ". . ." on tester #1?
@@ Also, you may have surmised, I got serial working on tester #2 (Fish8840) but I don't like this unit that much - it blew the "Z14" 3.3v reference when I first flashed a new firmware, and... well, I don't use it.
@@ Error? @@
Unit #1 (green screen, LCR-T4) complains with the message below, after each test when I give a long press for a subsequent test:
"Not calibrated!
For calibration clamp
the 3 pins together
and start with
the key. Acknowledge
the self-test with
the key within 2s.
Disconnect pins after
the message
"isolate Probe!" is
shown. Software and
documentation is at
svn://
mikrocontroller.
net/transistor tester "
Offline madires
« Reply #6598 on: November 03, 2020, 08:26:03 pm »
AFAIK, the k-firmware just displays "...". The animation could be a modified firmware.
@@ Error? @@
"Not calibrated!
Simply run the calibration. Please see https://github.com/madires/Transistortester-Warehouse/blob/master/Documentation/English/ttester-1.13k.pdf.
Offline Szybkijanek
« Reply #6599 on: November 04, 2020, 10:37:58 pm »
Something is with Your fw or my config because now I try with fw 1.13k Karl and all it's ok. I try Your older fw. I test 16MHz crystal and oscillation is correctly but LCD show wrong value. See picture.
" alt="" class="bbc_img" />
« Last Edit: November 04, 2020, 10:58:02 pm by Szybkijanek »
