1st, thank you to all that contributed to this project. It is amazing.
I noticed something interesting on a ST7735 display when I un-commented these 2 lines in the config_644.h file:
I wanted to see the effect, thought it would "move" the display to the side and to the bottom by 4 and 2 pixels.
#define LCD_OFFSET_X 4 /* enable x offset of 2 or 4 dots */
#define LCD_OFFSET_Y 2 /* enable y offset of 1 or 2 dots */
The display did not work 100% after this, had some "interference" on 2 sides, and some other odd effects on the displayed contents.
So I just put the // back in-front of the 2 lines, but the display did not return to its previous, good state.
I then did this, and it was good again.
#define LCD_OFFSET_X 0 /* enable x offset of 2 or 4 dots */
#define LCD_OFFSET_Y 0 /* enable y offset of 1 or 2 dots */
Is this the normal way to "reset" these settings?
