Author Topic: $20 LCR ESR Transistor checker project  (Read 3453354 times)
csuhi17, NikolaSoft and 11 Guests are viewing this topic.
Offline tom666
  • Country: sk
« Reply #1225 on: September 13, 2015, 08:29:14 am »
just a question, the frequency counter function in firmware 1.12k supports analog signals or just digital?
I think that what is important is the sufficient level of the test signal. For best input sensitivity it is necessary to set the supplement as described in the manual (2.2.4 Frequency measurement).
Works firmware that I uploaded for you in the previous post?
Offline torchTopic starter
« Reply #1226 on: September 13, 2015, 12:32:31 pm »
Does the transistor tester recognize this type of voltage regulator or is there something wrong with my tt's ?
I am far from qualified to say, but would think it very challenging to automatically detect and test a LM78xx voltage regulator within the scope of everything else this design does, without causing damage to components it already tests for. There are at least 3 challenges that I can think of off the top:
The 78xx series needs a supply voltage 2.5v higher than the regulated voltage, so in the case of the LM7812 pictured, it would have to apply 14.5 volts to the input. Not only does that have to come from the 9v battery, it can't cause damage to the low voltage devices this is designed to test.
The 78xx series come in a TO-220 case but are really more of a 3 terminal IC than a component. I don't know exactly what the transistor count is, but it's a busy little block diagram in the datasheet.
The 78xx series require a couple of external components to function properly. I think those would have to be switched into the circuit during the detection/test phase to properly test the output.
Of course, given all the challenges the designers have already overcome, I would never say "never"! But for the moment, maybe you are better to whip up a discrete test circuit of your own. Don't forget to add a heat sink to that thing if you draw more than 500mA while testing, or the thermal overload protection may shut it down, making it appear to fail the test.
Offline indman
  • Country: by
« Reply #1227 on: September 13, 2015, 01:36:17 pm »
Hello, friends! I ask forgiveness for my English in advance. I use the translator. For determination of parameters of voltage reference diodes and power conditioners there is a finishing of the hardware of a tester. Here one of possible diagrams which is developed and checked by the participant of the forum Vrtp.ru dear Ocela.
Offline tom666
  • Country: sk
« Reply #1228 on: September 13, 2015, 04:46:52 pm »
some time ago I drew attention to this great kit:
http://www.banggood.com/DIY-M12864-Graphics-Version-Transistor-Tester-Kit-LCR-ESR-PWM-p-986954.html
This tester is supplied with an earlier revision of the software v1.12k by Karl-Heinz Kübbeler.
Is used the G-LCD display with the controller ST7565 (in the standart SPI mode).
For other owners of this great kit I offer in the attached file recent version 1.12k (revision 523). It also includes a modified file "Makefile" for this tester. I tested this firmware.
Setting of the fuses [ATmega328p]:
lfuse:0xf7 hfuse:0xd9 efuse:0x04 [0xfc]
Note:
For reduce power consumption I recommend to change the series resistor for the LED backlight G-LCD to 680 ohm (the original value is 220 ohm). A further reduction in consumption could be achieved by replacing the 7550-1 to the Low Drop LDO (eg MCP1702-5002).
Bye
Tomas
Online yo0
  • Country: mx
« Reply #1229 on: September 14, 2015, 03:56:12 am »
thank you, no yet, i have no experience in programming microcontrollers, i am trying learn to use avrdude, unless you can please point me with the right instrucctions (commands) for backup the existing firmware and flash the new one you kindly provide to me, by the way already have an usbasp and installed already avrdude in linux and windows.
thank you in advance.
best regards
Pio
« Last Edit: September 15, 2015, 01:48:56 am by yo0 »
« Reply #1230 on: September 14, 2015, 04:48:43 am »
Is this a separate tester, just for regulators such as the LM78xx series? Or is it a new feature added to the transistor tester?
(Just wondering how wrong I was!  ;) )
Offline indman
  • Country: by
« Reply #1231 on: September 14, 2015, 06:54:50 am »
No, it not a separate tester. The basic firmware from Karl-Heinz Kübbeler with function of measurement of voltage reference diodes is used. Changes are made only in the tester hardware  :D
Offline tom666
  • Country: sk
« Reply #1232 on: September 14, 2015, 11:49:37 am »
i am trying learn to use avrdude, unless you can please point me with the right instrucctions (commands) for backup the exiting firmware and flash the new one you kindly provide to me, by the way already have an usbasp and installed already avrdude in linux and windows.
Commands for Windows
Writing Flash + EEPROM + Fuses:
avrdude -c usbasp -p m328p -B 0.5 -e -U flash:w:"TransistorTester.hex":a -U eeprom:w:"TransistorTester.eep":a -U lfuse:w:0xF7:m -U hfuse:w:0xD9:m -U efuse:w:0x04:m
Reading Flash + EEPROM:
avrdude -c usbasp -p m328p -B 0.5 -U flash:r:"TransistorTester_Backup.hex":i -U eeprom:r:"TransistorTester_Backup.eep":i
Another option is to use a GUI for AVRDUDE. I recommend AVRDUDESS.
« Reply #1233 on: September 14, 2015, 12:26:02 pm »
Well then. I guess I was almost completely wrong. How extensive are the hardware changes? Is this fork being made available in the same way as the original Karl-Heinz transistor tester?
Offline quantalume
« Reply #1234 on: September 14, 2015, 04:25:22 pm »
Note:
Bye
Tomas
It is indeed a great kit! Does one need to change the fuses from how they are supplied with the kit in order to run the new firmware?
Thanks for the suggestions for reducing power consumption. One could also increase the resistor value for the power LED as it's blinding in its current state.
Do you know of a case for this unit?  The case you linked to in the message where you introduced this kit (reply #1144, page 77) appears to be for a different design.
« Last Edit: September 14, 2015, 04:27:31 pm by quantalume »
Offline indman
  • Country: by
« Reply #1235 on: September 14, 2015, 04:39:24 pm »
Hi! Any tranzistortester it is simple to finish most. In the simplified look the converter DC-DC having on an output 35-40V for testing of voltage reference diodes and chips of stabilizators 78xx is necessary. The principle of such measurement explained Karl-Heinz Kübbeler in the instruction to the instrument on page 11. Maybe I badly explain? Excuse for my English. :)
« Last Edit: September 14, 2015, 04:43:37 pm by indman »
Offline rddube
« Reply #1236 on: September 14, 2015, 05:12:17 pm »
Many thanks, gentlemen :-+ :clap:
Best regards
Tomas
Here they can be bought individually, but I think rather expensive? What do you think?
http://www.ebay.com/itm/Transistor-Triode-Test-Socket-Ageing-Test-Socket-Ceramics-Body-TO92-TO220-TO3P-/311360707052
Tom666, why do you feel this is a much better connector than the zif socket? Should I change mine on my transistor tester? Tks
Offline klunkerbus
  • Electrical Engineer (retired early)
« Reply #1237 on: September 14, 2015, 05:52:28 pm »
rddube, the ZIF socket doesn't work out very well if you're installing the banggood tester with the 128x64 display into the plastic case that banggood offers for it.  (see http://www.banggood.com/Supporting-Shell-For-DIY-M12864-Graphics-Version-Transistor-Tester-Kit-p-989949.html ) That could be one reason.
I just assembled my tester and case, and I think I'd prefer the ZIF socket.  I've already been struggling to insert thin leads into the 5-pin socket without bending them. The contact fingers also look extremely cheap, and I won't be surprised if the contacts loose their grip with use.  For packages like TO-220, the 5-pin socket probably works great.
On the eBay part, the higher cost might make sense if it was truly a ceramic body, but the listing pictures don't convince me.
« Last Edit: September 14, 2015, 06:33:31 pm by klunkerbus »
Offline tom666
  • Country: sk
« Reply #1238 on: September 14, 2015, 07:00:16 pm »
In principle there is no need, but I recommend use a values of the software author.
Not recommended, it can then be a problem with the auxiliary power circuits.
The case, to which I post link is definitely designed for this kit. Please, see you the pictures carefully to the seller's site. ZIF socket for this case will not be used.
Offline bitseeker
« Reply #1239 on: September 14, 2015, 07:06:05 pm »
Exactly.
Quantalume, if you're going to use that case, don't install the ZIF socket on the PCB. Instead, use the socket that is supplied with the case. (i.e., It's not like cases for the other tester kits where the ZIF socket passes through an opening.)
Offline tom666
  • Country: sk
« Reply #1240 on: September 14, 2015, 07:14:19 pm »
In terms of design could be easier mounting on the case compared to ZIF socket. But I have some doubts about the quality of this connector.
Offline quantalume
« Reply #1241 on: September 14, 2015, 07:28:23 pm »
Exactly.
OK, I see how it works now. Too bad I already soldered the ZIF socket.  |O  Nothing a solder sucker can't fix I suppose.
Offline bitseeker
« Reply #1242 on: September 14, 2015, 08:22:18 pm »
Yep. All part of the DIY fun.  :D
Offline quantalume
« Reply #1243 on: September 15, 2015, 02:54:44 pm »
Could one cut the case to allow the ZIF socket to be used instead? I also see that there are only two binding posts. Could a third post be squeezed in and still leave room for the battery?
Offline giovannirat
  • Country: at
« Reply #1244 on: September 15, 2015, 07:33:49 pm »
As soon as i will get the case i try to cut it for the ZIF socket.
Thank you tom666 for providing the actual software. Works great.
Offline eas
    • Tech Obsessed
« Reply #1245 on: September 16, 2015, 01:03:14 am »
I plan to investigate the same questions when mine arrives this week.
Offline bitseeker
« Reply #1246 on: September 16, 2015, 01:44:38 am »
I'm looking forward to seeing everyone's case mods. I ordered one of the testers with the encoder, but not the case (yet).
Offline tom666
  • Country: sk
« Reply #1247 on: September 16, 2015, 06:58:55 am »
Very elegant solution :-+ :clap:
Thank you for the inspiration.
Offline madires
« Reply #1248 on: September 17, 2015, 07:02:26 pm »
Just a quick update on the m-firmware. Currently I'm working on a driver for ILI8341/ILI8342 based colour LCD modules and larger fonts. I'll also try to add the fancy pinout in the next version.
Offline papabol_24
« Reply #1249 on: September 18, 2015, 04:24:17 pm »
I need help guys in figuring out whats wrong, i have one of these LCR ESR Transistor checker with case, very handy gadget, till one day i accidentaly dropped it, screen cracked so i looked for a replacement 12864 lcd module, bought a bigger size lcd bec i cant find exact size, and when i hooked it up to the characters are inverted, photos attached, thanks in advance...
LCD module link
http://www.aliexpress.com/item/JLX12864G-378B-PC-12864-lattice-COG-type-serial-and-optionally-3-3v-5V-optional/32278219453.html
Transistor Tester link
http://www.aliexpress.com/item/Multi-functional-LCD-Display-Digital-ESR-Meter-Transistor-Tester-Diode-Thyristor-Capacitance-LCR-Tester-Grey-Plastic/32423335203.html?spm=2114.01020208.8.78.y2luTw
