Author Topic: New Rigol DS1054Z oscilloscope  (Read 2068767 times)
Offline donmr
  • W7DMR
« Reply #1075 on: February 18, 2015, 08:45:04 pm »
Does anyone know why I might be getting out of phase glitches that appear on the screen when measuring say a 10 KHz sine wave from an audio source?
The problem sometimes goes away if I use the small metal spring instead of the aligator clip for grounding. Can it be a problem with the amplifier or is it a loose connection? I'm confused. |O
If you see these glitches when you use the ground wire (several inches long) and not with the short spring clip ground then the most likely cause is that you are receiving some RF signal with that ground wire acting as an antenna.
One quick way to check for this is to clip the ground clip to the tip of the probe and hold it near your circuit, but not touching anything.  If you still see the glitches then they are coming through the air (as RF) from somewhere.  Move the probe around and see if the source is nearby or farther away.
You can also try turning off (and unplugging) devices to see if the glitches go away then.
Offline Tainer
« Reply #1076 on: February 18, 2015, 10:33:57 pm »
This may not be related to your phase glitches, but I noticed an issue with one of the probes.
Most of the time I set the probes to x1 attenuation, since I don't need the bandwidth. I noticed that sometimes the amplitude suddenly starts to drop/bounce. When I switch to x10 the problem goes away. I think the attenuation switch is a bit dicky.  I made a couple of tests to make sure it's not a bad connection and I'm pretty confident that the switch is to blame.
Offline drummerdimitri
  • Country: lb
« Reply #1077 on: February 19, 2015, 12:16:11 am »
I am using the probe with x10 attenuation. It must be something else.
Offline smgvbest
    • Kilbourne Astronomics
« Reply #1078 on: February 19, 2015, 02:31:03 am »
It doesn't help when every request shows PM sent instead of how to get it.
True.  I was able to get it quickly by opening a chat session at the site.  I'm guessing there's a rule about posting it in the forum (maybe to encourage registration), but it's certainly not a closely guarded secret.
Can you please PM me the Rigol code? Thanks!
PM Sent
Sandra
(Yes, I am a Woman :p )
Offline yeltrow
« Reply #1079 on: February 19, 2015, 07:36:20 pm »
May I please also have the discount code?
Offline nanofrog
« Reply #1080 on: February 19, 2015, 07:41:36 pm »
PM sent.
Offline ishmael1851
« Reply #1081 on: February 19, 2015, 08:59:20 pm »
Hi, could I have the discount code for tequipment.com as well?  Does it apply to the DS2000 series?  And is it only valid outside the US?  Thanks!
Offline nanofrog
« Reply #1082 on: February 19, 2015, 09:21:22 pm »
Yes, it will apply to the DS2000 series. PM sent.
FWIW, there's a dedicated thread for the code.
Offline vacaloca
« Reply #1083 on: February 24, 2015, 07:18:59 pm »
I didn't find the dedicated thread. Could you post a nudge and/or PM discount code? Thanks!
Offline nanofrog
« Reply #1084 on: February 24, 2015, 07:50:11 pm »
Searching "Tequipment code" or "Tequipment thread", would have gotten what you wanted, including the thread Special Price FOR EEVblog Members:)
PM sent.
Offline gmit77
    • Batter Fly
« Reply #1085 on: February 25, 2015, 11:57:12 am »
for EU people we will have stock starting this Friday:
RIGOL DS1054Z http://www.batterfly.com/shop/rigol-ds1054z
BUNDLE RIGOL DS1054Z + HAKKO FX888D http://www.batterfly.com/shop/bundle-ds1054z-fx888d
BUNDLE RIGOL DS1054Z + SALEAE LOGIC 4 http://www.batterfly.com/shop/bundle-ds1054z-logic4
HOPE IT HELPS
CIAO  :-+
« Last Edit: February 25, 2015, 02:03:11 pm by gmit77 »
Batter Fly
never stop innovating
Offline Bryan
« Reply #1086 on: February 25, 2015, 09:26:39 pm »
Is the DS1054Z in stock at TEquipment?
What is the best place to buy one in Canada?
rigolcanada.com or http://www.electro-meters.com
Prices from electro-meter seem fair. Has anybody ordered from them before?
-=Bryan=-
Offline BlueBill
« Reply #1087 on: February 25, 2015, 09:40:50 pm »
Yep, no problem. They're out in Pickering, more an office than a store. Call them ahead if you want to pickup and pay on CC.
Offline Bryan
« Reply #1088 on: February 25, 2015, 10:20:13 pm »
Thanks, on the West Coast. Will give them a call. Assume they are the authorized dealers for Rigol if any issues.
-=Bryan=-
Offline BlueBill
« Reply #1089 on: February 25, 2015, 10:28:52 pm »
I think they're the only Rigol dealer in Canada. Their Rigol site is www.rigolcanada.com
Offline Paul Moir
« Reply #1090 on: February 25, 2015, 11:05:33 pm »
RAE out here on the East coast.  I haven't checked their Rigol prices lately, but I remember a while ago they seemed good.
EDIT:  I guess TMetrix too.
« Last Edit: February 25, 2015, 11:24:39 pm by Paul Moir »
Offline Didix
« Reply #1091 on: February 28, 2015, 06:57:27 am »
Do the 4 channels share a same ground?
Or are the 4 channel working as independent differential inputs that float in respect to each other?
-Didix
Fluke 76 | UT61E | UT139C | UT70A | UT50E | UT132A | UT33C | UT203 | UTG9002C
Offline rob77
  • Country: sk
« Reply #1092 on: February 28, 2015, 07:08:13 am »
-Didix
same ground for all 4 channels - same as the majority of the scopes ;) to get a floating input you need a differential probe.
Offline miguelvp
« Reply #1093 on: February 28, 2015, 07:22:11 am »
-Didix
Or detach the ground clips in two probes and use the probes and math function CH1-CH2 (A-B) for example, as a differential probe, but the math function in the ds2000 is a bit slow, so it's probably as slow in the DS1054Z.
By slow I don't mean that you will loose the signals, but the display will lag displaying the output if trying to look at the signal "live"
« Last Edit: February 28, 2015, 07:25:19 am by miguelvp »
Offline rob77
  • Country: sk
« Reply #1094 on: February 28, 2015, 07:39:06 am »
-Didix
yes, that's a OK, but you have to keep the input rating in mind... it's 300V CAT I for the DS1054Z, so you can't probe anything directly connected to mains (you can't probe the primary side of a SMPS for example).
with a diff probe you can have higher rating - 500V CAT II is good enough. (and therefore you can probe the primary side of a SMPS for example).
« Reply #1095 on: February 28, 2015, 08:51:14 am »
And also connected to mains ground - watch out where you connect the ground clip of your probes!
Offline Didix
« Reply #1096 on: February 28, 2015, 01:54:32 pm »
YEP! with my old analog scope I just vaporized a fuse of a power supply due to that fact.
Thats' why I am looking for something that floats  ;D
I just use it on my bench. Nothing higher than 24VAC.
-Didix
Offline Didix
« Reply #1097 on: February 28, 2015, 01:59:17 pm »
-Didix
Is that math function included in the basic package of the DS1054Z?
-Didix
Offline Datman
« Reply #1098 on: February 28, 2015, 02:46:22 pm »
NOISY...  :(
Hi all
I have received my new DS1054Z just yesterday.
I noticed some noise on the track. It's still there also with the inputs set to GND... Sometimes I can see little rectangular waves, other times sawtooth, sometimes I see 3mm of noise also in 1V/div. If I do something, then I come back, sometimes track become thin, with only a little, acceptable noise.
Do anyone have a similar problem on his DSO? Do you have some hints?
Thanks!!!
« Last Edit: March 03, 2015, 06:07:34 pm by Datman »
Offline nanofrog
« Reply #1099 on: February 28, 2015, 03:02:07 pm »
Now I noticed some noise on the track. It's go there also with the inputs set to GND... If I have to return it I have to reset options! How can I do it? Do you have some hints?
Use the SCPI command :SYSTem:OPTion:UNINSTall, then reboot the oscilloscope.
« Last Edit: March 03, 2015, 08:41:00 pm by nanofrog »
