Author Topic: Siglent Bench DMMs SDM3065X, SDM3055 and SDM3045X  (Read 392458 times)
Offline KungFuJosh
  • TEAS is real.
Re: Siglent Bench DMMs SDM3065X, SDM3055 and SDM3045X
« Reply #1675 on: January 29, 2024, 05:48:22 pm »
Well, I was in 10bit mode, so it was probably 6bits. 😉😉
Anyway, here it is also being accurate in 10 and 20mV/div.
Using SDG2122X as a ref.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Online mawyatt
« Reply #1676 on: January 29, 2024, 07:27:46 pm »
Using a SDG2042 at 1KHz (Edit:10KHz), {100KHz} Sine, [10KHz Triangle], 1Vrms setting, we just did a quick sanity check with these, all in Vrms (SD):
SDS2000X+  in 10 bit mode           1.007 (1.007) {1.009) [1.004]
DHO814                                       1.004 (1.009) {1.005} [1.007]
SDM3065X 3Hz filter and average  0.999047 (0.999591) {1.002099} [0.999194]
KS34465 #1 3Hz filter and average 0.9999419 (1.0005105) {1.0008633} [1.0001987]
KS34465 #2                                 0.9999388 (1.0005261) {1.0005467} [1.0001601]
DMM6500  3Hz filter and average   0.9999689 (1.000422)  {0.9996228} [1.000037]
AG34401A  3Hz filter                    1.00001 (1.00057) {0.998214} [1.000133]
These DSOs are somewhat respectable for lower frequency AC RMS measurements, agree well with various DMMs, and of course should well outperform any DMM at higher frequencies.
The two KS and the DMM6500 utilize digital sampling techniques, while the SDM3065A  and AG34401A utilize old school analog (AD636 maybe) techniques.
Would be an interesting involved test to see how well these old school techniques behave relative to the newer sampling techniques wrt to rms readings at various frequencies, amplitudes and crest factors.
Best,
« Last Edit: January 29, 2024, 11:47:44 pm by mawyatt »
~Wyatt Labs by Mike~
The following users thanked this post: Performa01, egonotto, tautech, exe, Mortymore, colorado.rob, KungFuJosh, Martin72
Online Martin72
  • Testfield Technician
« Reply #1677 on: January 29, 2024, 09:01:58 pm »
Interesting, I'll go along with that. ;)
(SDG2122X, 1khz, 1Vrms,Hi-Z)
SDM3065X : 1.00305 Vrms
Brymen BM859s : 1.0041 Vrms
SDS2504X HD DVM : 1.006 Vrms
SDS2504X HD : 1.00658Vrms
Oh yes,
The day before yesterday a used SDM3065X-SC slipped through my fingers, the seller only wanted €600 for it, saw it too late.... :P
The following users thanked this post: egonotto, KungFuJosh
Offline KungFuJosh
  • TEAS is real.
« Reply #1678 on: January 29, 2024, 09:16:20 pm »
Nice, looks like a lot of trustworthy numbers to me. 😉
Online Martin72
« Reply #1679 on: January 29, 2024, 09:21:50 pm »
And in reality we don't know anything, that's metrology. ;)
The generator as an AC source to check...I didn't realize that... 8)
Offline KungFuJosh
  • TEAS is real.
« Reply #1680 on: January 29, 2024, 09:56:59 pm »
Yes, yet another reason I'm glad you convinced me not too sell it. 😉
And thanks to @J-R for the suggestion of using it as an AC ref.
Online mawyatt
« Reply #1681 on: January 29, 2024, 10:04:28 pm »
Guess we can infer that the SDG2042X provides a reasonably stable output in these ranges, that the SDM3065AX
 agrees well with the other DMMs, and that the different techniques to extract an RMS readings agree well.
Edit: we added some more readings above.
Best,
« Last Edit: January 29, 2024, 11:35:29 pm by mawyatt »
Offline delvo
« Reply #1682 on: January 29, 2024, 10:24:56 pm »
Can I play too? The ones that were within arms reach:
(SDG2042X (SDG2122X), 1khz, 1Vrms, Hi-Z)
34401A      1.002113 Vrms
SDM3065X   1.001751 Vrms
SDS1204X-E   1.01 Vrms (not the most useful resolution on this one)
Fluke 28 II        1.0034 Vrms
UT139C       0.998 Vrms
ZT-702S (M)      1.000 Vrms
ZT-702S (O)      1.00 Vrms
The following users thanked this post: egonotto, KungFuJosh, Martin72
Offline exe
  • self-educated hobbyist
« Reply #1683 on: January 30, 2024, 08:38:15 am »
How about rising frequency to, say, 10kHz and 100kHz?)
Online mawyatt
« Reply #1684 on: January 30, 2024, 01:25:18 pm »
See # 1676 above, edited with Sine at 1, 10, 100KHz and Triangle at 10KHz.
Best,
Online tautechTopic starter
« Reply #1685 on: January 30, 2024, 03:28:35 pm »
Anyone have their SDM3065X open to help identify some fried parts ?
https://www.eevblog.com/forum/repair/siglent-sdm3065x-repair/
TIA
Offline vikrep
« Reply #1686 on: February 03, 2024, 09:11:58 am »
Hello! Can anyone help with the question. I want to buy a RS-PRO RSDM-3055 second hand multimeter, but it doesn’t have documentation and software. I asked the RS-PRO company to download the software EasyDMM, but they refused without invoice number. Is the software from Silent SDM3055 compatible with RS-PRO RSDM-3055 and is it possible to update the firmware there or re-flash firmware fully to Siglent?
Thank you.
« Reply #1687 on: February 03, 2024, 09:16:22 am »
Thank you.
Work through the list of downloads here:
https://int.siglent.com/download/?ProId=26
Offline figurativelythedevil
« Reply #1688 on: March 08, 2024, 02:41:14 pm »
Posted this in another thread but was pointed here.
I'm having an issue with my SDM3065X-SC, not sur if anyone's run into this before. Did a bit of looking and couldn't find an obvious answer.
I have my meter connected to PC via USB, and I'm trying to use EasyDMM to set up a scan, I have 5 thermocouples and 2 voltages I want to monitor. I can set up all the scan parameters with no issue, but when I connect to the meter to push the scan config and actually scan, the meter just locks up and I get an error in EasyDMM saying Failed to Query. Setting up the scan directly on the meter works fine and it scans no problem.
Does anyone know what's going on? I have the latest firmware & software revs. I've read the manuals and am following the instructions therein.
Offline KungFuJosh
  • TEAS is real.
« Reply #1689 on: March 08, 2024, 02:53:25 pm »
Since it sounds like you have all the device and software configs correct, the error is likely due to a comm issue. Possibly the ethernet cable, or firewall settings in your computer or router. For example, if the device and/or software expect 2-way communication, but maybe only one direction is working, that could cause an issue.
Offline coromonadalix
« Reply #1690 on: March 08, 2024, 03:07:47 pm »
good quality cables too
lan example
i have Siglent stuff in automated project,  if the cable are poorly made,  i have failed communications, and we don't run them at maximum output
tried for fun  some "flat" lan cables and they all fail  loll
Offline KungFuJosh
  • TEAS is real.
« Reply #1691 on: March 08, 2024, 03:35:25 pm »
Absolutely, good cables are a must. I only use over spec'd shielded cables.
« Reply #1692 on: March 08, 2024, 07:53:29 pm »
I'm currently connected via the USB that came in the box. Also, using the standard "Measure" feature instead of "Scan" works with no issues in EasyDMM. The trouble seems only connected to the scan function.
Offline KungFuJosh
  • TEAS is real.
« Reply #1693 on: March 09, 2024, 12:02:19 am »
Could be the USB port. USB2 vs USB3 some devices are pickier about using them. However, cables that come with stuff I usually throw in the trash. 🤷
Offline phecap
« Reply #1694 on: March 27, 2024, 12:06:16 pm »
A few weeks ago I purchased a Siglent SDM3055.
The device has firmware version 1.02.01.28 installed.
This version cannot yet be downloaded from www.siglenteu.com.
Does anyone know what has changed compared to version 1.01.01.27R2?
Offline james38
« Reply #1695 on: March 30, 2024, 02:31:02 am »
I think that you have probably benefited from having an upcoming update
that will probably only be officially rolled out later.
But maybe it's a version written for a new hardware version.
I see that this one has V 03-00-00-13-00
I have here from V 02-00-00-11-00
« Last Edit: March 30, 2024, 02:34:38 am by james38 »
The following users thanked this post: phecap
Offline Mortymore
  • Country: pt
« Reply #1696 on: March 30, 2024, 10:48:13 am »
I have an SDM3055 with the HW version 03-00-00-13-00 bought over a year, and the SW version is the 1.01.01.27R2 (and I might have updated it when the SDM arrived)
On the other hand I have an SDM3045X,  6 months old, HW version 03-00-00-05-00 that came with the SW version 5.02.01.09R2 that I never hacked because of that 02 in the SW version.
I don't know what's the difference between versions 01 and 02 in the software, but the 02 ones are not available for download, only being deployed with recent SDMs
Offline KungFuJosh
  • TEAS is real.
« Reply #1697 on: April 07, 2024, 12:38:08 am »
Soooo I might have bought an SDM3065X.
SW 3.02.01.12R1
HW 02-02-00-05-00
This toy is a little different than the "lesser" models... So I RTFM. But it's still odd. It looks like the manual incorrect with DCV. This is what the manual (E02B) shows:
But this is what my DMM shows for DCV:
Doesn't matter what Aperture is set to, the average is 1.4mV with nothing connected (either no probes, or with probes not touching anything). I understand that there's Rel, or manual calibration where I can probably zero that out, but should I really need to?
ETA: Auto Zero doesn't appear to do anything.
With a voltage source it does appear quite stable.
« Last Edit: April 07, 2024, 01:56:55 am by KungFuJosh »
« Reply #1698 on: April 07, 2024, 02:18:59 am »
Floating 10G Ohm inputs......
Open inputs could indicate anything, short them.  :P
« Last Edit: April 07, 2024, 02:20:59 am by tautech »
Offline KungFuJosh
  • TEAS is real.
« Reply #1699 on: April 07, 2024, 02:33:17 am »
Shorted it seems normal ~7µV. The 3055 is ~6µV shorted, not a big deal. My question is if I should be concerned about the open value or not. Is that a sign of anything I should be concerned about? I have 3 SDM models, and only the 3065 does that open.
OTOH stability is excellent. Here's a comparison:
3065X:
3055:
I'm guessing this might be another case of me needing to let the stupid thing run for a while. 🤷
« Last Edit: April 07, 2024, 02:37:58 am by KungFuJosh »
The following users thanked this post: Performa01, tautech
