Author Topic: Unicode  (Read 13615 times)
Offline IanMacdonald
    • IWR Consultancy
Re: Unicode
« Reply #50 on: April 22, 2018, 11:36:59 am »
The big problem with unicode is that it's become a fragmented standard, with numerous different implementations. Worst is Microsoft Word's use of characters that are only available in 32-bit unicode. For no sensible purpose either, the characters in question are just a fancy style of double quotes. So for the sake of this stupid piece of frippery they've created a problem for everyone.
On the Web, pages tend to use UTF-8 but Javascript only understands UTF-16, and PHP basically doesn't understand Unicode. So, when you try to do string comparisons on Web data the outcome is basically pot luck.
A problem you frequently meet is that of unicode filenames on websites, where the file can be saved to disk but cannot be opened by the associated application.
Offline gnif
Re: Unicode
« Reply #51 on: April 22, 2018, 12:44:45 pm »
Well in all instances we are covered now, the database is using utf8mb4 (4-Byte UTF-8 Unicode Encoding) which covers every possible encoding.
Offline RoGeorge
Re: Unicode
« Reply #52 on: April 22, 2018, 01:31:27 pm »
Nice work, but why bother the effort?
If the answer is "just to display +/- like symbols", then it doesn't makes much sense, IMO. It's an English forum, mainly for electronics related topics of EE. I don't think EEvblog users have difficulties understanding what uV stands for. Probably most of the users won't waste time looking how to type the appropriate symbol anyway.
I think the real answer is because I can, and because it is cool to have it. Long story short, I'm not a fan of Unicode. It comes with a lot of problems, but no major benefits for English.
Online T3sl4co1l
    • Seven Transistor Labs
Re: Unicode
« Reply #53 on: April 22, 2018, 02:01:51 pm »
The problem was worse than that: at best, 7-bit ASCII was supported, not even a traditional full 8-bit encoding like CP437 or ISO-8859-1.  Extended characters are commonly encountered: besides the  \$\Omega\$ hack which we no longer need on the toolbar*, even just simple things like accents ("naïve" makes it into the English dictionary), let alone foreign language excerpts which were completely impossible to quote here.  It's hard to discuss something, even if the discussion is in unaccented English, when the source is not. :o
*But, speaking of which, since we still have jsLaTeX here, I wonder if we could add a button or two, e.g., "insert inline math", "insert display math", and it's just a dialog where you enter your code.  (But preferably, the dialog could also have a link to the code reference, or some helpers or such -- this could get quite deep quite quickly of course, and that immediately moves beyond the capability of an alert dialog, to a full HTML-CSS popover workbox or the like, and...)  Just something simple like that, I think would help improve its use. :)
Tim
Seven Transistor Labs, LLC
Offline wraper
  • Country: lv
Re: Unicode
« Reply #54 on: April 22, 2018, 02:23:19 pm »
Yeah it's certainly "better" when thousands of people constantly jump through hoops and figure out workarounds instead of fixing the problem at it's core a single time  :palm:. And it's not nearly limited to +/-.
The following users thanked this post: Zbig
Offline Karel
Re: Unicode
« Reply #55 on: April 22, 2018, 02:40:26 pm »
Every single EE, around the world, as you stated, without any additional localization or clarifications, must read basic English.
Practically, yes. How else can they do their job?
By reading datasheets that are printed in another language, like Mandarin.
Where do you find them at, for example, the website of Texas Instruments?
http://www.ti.com.cn/product/cn/MSP430FR2000/technicaldocuments
That took, like, three seconds.
Wow, I didn't know that. Impressive! What about Microchip, STMicroelectronics, Maxim Integrated and Nexperia?
Offline AmperaTopic starter
    • Ampera's Forums
Re: Unicode
« Reply #56 on: April 22, 2018, 02:56:21 pm »
We weren't even using ASCII, as old English characters like þ, ð, and æ I know worked.
Not to mention why are you even complaining? It's not like it affects you, or anybody else in any significant way. Complaining about the fact that you have more hardware characters to work with is like complaining that you hate the typewriter your using because you can do 90 WPM on it and it doesn't jam, whereas your old one jammed at 30.
This is an English EE forum, but we still can find use for more characters. The upgrade has been done, and by the sound and time of it, I don't think it was that much of an extra hassle.
Another thing. I actually found it impressive that Ti had Chinese spec sheets on their website, considering they are out of Texas. Just take a look at how many electronics companies there are in China and Japan. You can see that there are datasheets in other languages, if they are being made in other languages, there must be EEs reading them.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
Offline Monkeh
Re: Unicode
« Reply #57 on: April 22, 2018, 02:56:55 pm »
I suggest you answer your own question by following the same steps I did:
1: Go to their website
2: Pick a random part
3: Look for a langauge option
Offline Karel
Re: Unicode
« Reply #58 on: April 22, 2018, 04:49:22 pm »
Ok I checked the Microchip website: No language options, neither for the datasheets or the website.
STMicroelectronics: website can be set to chinese or japanese. Datasheets remain in english only.
Maxim Integrated: website can be set to chinese or japanese. Datasheets remain in english only.
Nexperia: website can be set to chinese. Datasheets remain in english only.
So, electronic engineers don't need to be able to read basic english? They simply avoid the above manufacturers (and probably others as well)?
Re: Unicode
« Reply #59 on: April 22, 2018, 04:53:09 pm »
Carol (I've anglicized your name as that would seem to suit your sensibilities more), what is it that you hope to get, to achieve, with this line of argument?
Offline Karel
Re: Unicode
« Reply #60 on: April 22, 2018, 05:01:32 pm »
Originally, it was a reply to the reply of TwoOfFive who stated that electronic engineers can still do their job when they are not able to read
basic english: https://www.eevblog.com/forum/chat/unicode/msg1487445/#msg1487445
    • Ampera's Forums
Re: Unicode
« Reply #61 on: April 22, 2018, 05:28:43 pm »
Which is true. There are non-English datasheets in the world. To my knowledge, most of that technical writing is done by EEs, so if they can all magically understand English, why do Chinese datasheets exist?
Not to mention, just because those specific, likely US/Europe oriented websites don't have their datasheets in another language, doesn't mean it doesn't exist. I bet you that in order for an EE company to be taken seriously, they have to release datasheets in Mandarin.
Your logic is worse than Jeremy Clarkson's.
Offline Karel
Re: Unicode
« Reply #62 on: April 22, 2018, 05:52:35 pm »
Probably the situation is getting slowly better for chinese engineers.
Maybe in the future an EE only needs to be able to read basic english or basic mandarin. Who knows.
What about EE's in Europe (apart from the UK ofcourse), should they be able to read basic english?
What about EE's in Mexico and South-America? Russia? The Middle-East?
You think EE's don't need to be able to read basic english?
Offline IanB
Re: Unicode
« Reply #63 on: April 22, 2018, 06:59:53 pm »
TwoOfFive probably hasn't seen the world much. Anyone you meet in a professional context from any part of the world will have some competence or fluency in English. English is the international language of communication.
Trust me, I have decades of professional experience working as an engineer, and everyone I have worked with from anywhere, be it Asia, Europe, Middle East, Africa, South America, anywhere in the world, they all have conversed naturally in English, both spoken and written. It may be unfair they have to do this when native English speakers get a free ride, but it is how it is.
Offline Monkeh
Re: Unicode
« Reply #64 on: April 22, 2018, 07:02:05 pm »
One language has to win - right now it's English.
Offline BillB
Re: Unicode
« Reply #65 on: April 22, 2018, 07:25:10 pm »
As a 'Murican who only speaks 'Murican, I'm thankful for this.   :D
Not that I'm completely unworldly; I did study French for four years in school.  But where did that get me?  Nulle part!
    • Ampera's Forums
Re: Unicode
« Reply #66 on: April 22, 2018, 07:51:01 pm »
By absolutely no means get me wrong, I will concede that the majority may have some English knowledge, but there must be some groups of EEs that don't. Considering there are only 1.5 billion English speakers in the world, I find it hard to believe that entire 6 billion person group does not have any EEs in it.
If we want to talk about what language will win in the end, we all know it's going to be Cornish. The widespread acceptance of the language and it's mass appeal makes me think that it's current speaker base of only 500 will be completely temporary.
Offline wraper
  • Country: lv
Re: Unicode
« Reply #67 on: April 22, 2018, 08:24:05 pm »
Offline wraper
  • Country: lv
Re: Unicode
« Reply #68 on: April 22, 2018, 08:30:57 pm »
Do you realize there are tons of components with names using Cyrillic and datasheets in Russian only? In the past you couldn't write such part number properly, and adding picture did not help much as people wouldn't be able to type them in the search anyway. Say, ЭКР1568ХА2 or КТ361Б, even P and X are not what you may think. They are completely different letters and same looking Latin letters won't work for search.
« Last Edit: April 22, 2018, 08:37:58 pm by wraper »
Offline wraper
  • Country: lv
Re: Unicode
« Reply #69 on: April 22, 2018, 08:50:37 pm »
If you count native and non native speakers together, English and Mandarin Chinese are on par. As of native speakers, Mandarin wins by factor of 2.5.
Offline IanB
Re: Unicode
« Reply #70 on: April 22, 2018, 08:53:29 pm »
But that isn't the question. If engineers from different countries with different languages meet, or exchange emails, or hold telephone calls, they converse in English, not Chinese...
Offline wraper
  • Country: lv
Re: Unicode
« Reply #71 on: April 22, 2018, 08:56:58 pm »
The fact is there is too much stuff available in non English only which was never intended for English speakers. And time to time people ask for help or just want to discuss that. If you think that all world spins around English, you are wrong.
« Last Edit: April 22, 2018, 09:07:47 pm by wraper »
Offline wraper
  • Country: lv
Re: Unicode
« Reply #72 on: April 22, 2018, 09:04:16 pm »
What you are talking about is confirmation bias. Sure you were taking with people who speak english to some extent. Because those who don't won't speak/work with you, to begin with.
Offline Karel
Re: Unicode
« Reply #73 on: April 22, 2018, 09:08:43 pm »
Offline Karel
Re: Unicode
« Reply #74 on: April 22, 2018, 09:10:37 pm »
How does that help an EE in Mexico? Or Brazil?
