Greetings
Here are some pics of my home workshop. As you can probably tell I've been doing this a while, and working from home helps justify it. Until three months ago I had a 6'x6' space, but having moved house I now have my own man cave.
I am an embedded RF mixed signal guy, so it's hardware and software. Those two 4K monitors are awesome for development!
On the first picture, the stack is
HP calibration kit for vector network analyser (below)
Instek 3MHz function generator
Marconi 6950 RF Power Meter with 6910 sensor calibrated to 18GHz
Tait T801 Rubidium frequency reference, heavily modified so multiple outputs are on the front :-)
HP 8656B RF signal generator 0.1-990MHz
HP 8565A RF spectrum analyser 10MHz-22GHz
Anritsu MT8802A communications test set 300kHz-3GHz
HP 8753A 300kHz-3GHz vector network analyser (with a T/R test set)
Reflow toaster oven
AR8600 communications receiver
Several assorted power supplies
Saike 898D hot air solder station
Rigol MSO1074Z-S 70MHz 1GSa/s 4+16ch scope
Agilent 54831D 600MHz 4GSa/s 4+16ch scope
Stereo Microscope (under the translucent cover)
Two Weller soldering irons plus a Weller tweezer with control boxes
Under the desk:
Marconi 2955A comms test set to 1GHz
Tektronix TDS 2024B scope 200MHz 2GSa/s 4ch
Anritsu Site Master S331A 5MHz-3.3GHz one port portable VNA
TTi PSA2701T handheld spectrum analyser to 2.7GHz
Several multimeters and component testers
RFD 2305 calibrated RF noise source to 3.4GHz
NGA noise gain analyser to 1.8GHz for noise figure measurement
Intronix Logicport LA1034 USB logic analyser
Bitscope BS50 USB scope and logic Analyser
