Thank you guys...
Unfortunately, I haven't even approached to curing device
![Sad :(](https://www.eevblog.com/forum/Smileys/default/xsad.gif.pagespeed.ic.L3FGyzQrjB.png)
I am obviously stupid
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif.pagespeed.ce.8iLbFYV4Bc.gif)
but I cannot install FLIR drivers ver 1.9.
Here is what I do:
-Install drivers on WinXP Pro SP3
-Reboot PC
-Hard off the camera
-Boot PC
-Login Windows
-Then I plug the USB and
IF the camera was off or stand-by it shows battery, but nothing else. However, New Drivers are found on my PC, which is FLIR USB Device, Flir Video etc., as it should be.
However, in a moment these names are replaced with Generic USB Volume and Generic USB video.
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif.pagespeed.ce.oZptHNcbsD.gif)
IF the camera was already full-on, it behaves quite the same.
I tried to manually locate and replace drivers from the Drivers installation folder. There I found 2 versions of Video USB Driver and USB device driver, among others.
But none of them installed! It keeps saying: there is no info about hardware in this *.inf WTF&!!!*@($*&$$@(&&
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/xhuh.gif.pagespeed.ic.6Nvt7O8a11.png)
I also tried to connect FlirInstallNet with this drivers. It does, however it lists Generic USB video only and not FLIR.
It connects to the device, but I am afraid to use 'wrong drivers' for such the important and risky operation.
I tried to GetHwInfo and check files buitton in the utility. In the first case it mostly returns empty strings in a message box.
In the second, it complains there is no CRCkit and ProdKit found...
I am about to panic
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/xsmiley.gif.pagespeed.ic.R8GFI-pF6f.png)
