SMB 1.0. My NAS is rather old and does not support anything better.
Is there any documentation about setting it up? It is, or should be, fairly simple unless they have done something weird. I'm using:
Drive letter: Z:
Directory: //[server_name]/share
User: [server_name]/[user_name]
Password: [password]Result: Mount directory error: please check your parameters!
I have tried slashes the other way in various combination. I've tried not including the [server_name] in the user name. I've tried different drive letters. The NAS is a Thecus N4100PRO and it's running a form of Linux.
Update: Never mind. Even though prompts in the setting page suggest using the server name, the scope seems to have a problem with name resolution. I tried the IP address of the server and it worked. Thanks for helping out.
Update #2:
So this is what worked for me:
Drive letter: I:
Directory: //[server_IP]/[share_name]
When is saves something, the scope creates a directory called "SIGLENT" on the specified share and stores files there.
Just an opinion, but if Siglent want to considered a top tier brand, they will have to up their game on documentation. Any time a feature is added or amended they should create and publish an addendum to the documentation and/or update the documentation.
Also in the release note for 1.5.2R1 - "Supported time zone setting"
![Sad :(](https://www.eevblog.com/forum/Smileys/default/xsad.gif.pagespeed.ic.L3FGyzQrjB.png)
