Do Microchip PICKIT3 and Ebay PICKIT3 Clones Work Identical?
Posted by
SuzyC
on 05 May, 2015 00:02
I want to program Microchip PIC chips, and I need something like a PICKIT3 to allow me to program new chip models.
I see on ebay that the PICKIT3 clone offerings are up to 6x(oops..maybe 1/2 as much) cheaper than the genuine Microchip device.
I want to use HV mode on the Vpp pin for programming the PICS and I also most always want to program using the PICKIT3 directly from a DOS IDE compiler generated INTEL HEX File.
My question is: Is there any HV programming mode or other limitations in the ability to program all PIC device types using a clone PICKIT3?
Is it that the programming instructions for each chip must be downloaded from a Microhip IDE program to the PICKIT3 or that the firmware that comes with PICKIT3 contains a program with this programming info?
If there is PICKIT3 firmware, is it then possible to just download the latest software/firmware/Chip Programming Procedure info for the PICKIT3 that will work on a clone PICKIT3 from Microchip?
#1 Reply
Posted by
oPossum
on 05 May, 2015 00:17
I see on ebay that the PICKIT3 clone offerings are up to 6x cheaper than the genuine Microchip device.
Where do you see them for $8. The real thing is $48.
From DOS??? Can't do that with PICKit. Windows, OS X or Linux only.
#2 Reply
Posted by
chibiace
on 05 May, 2015 00:20
mplabx comes with a standalone program for uploading hex files
#3 Reply
Posted by
SuzyC
on 05 May, 2015 00:45
Thanks to all, actually some of the clones are mostly close to half the price..I saw the higher price looking at a development board price that included a PICKIT 3 from Newark.
The question remains..do PICKIT 3 clones offer the same functionality and ability to program yet to be released newer chips?
Is the chip programming info always part of the MPLABX package and independent of the PICKIT 3 firmware?
Does the MPLABX software allow me to use hex files generated by a Hi-Tech compiler or is it that the hex files must have a different format that only results from compiling with MPLABX?
#4 Reply
Posted by
oPossum
on 05 May, 2015 01:30
You can use Microchip's IPE (Integrated Programming Environment) software to program hex files from any compiler or assembler. The hex format used by PICs has be documented and standardized for a long time.
If you buy a cheap clone from china you get whatever they send you. Get the real thing for $20 more and avoid all the possible problems with a clone.
#5 Reply
Posted by
neslekkim
on 05 May, 2015 05:23
#6 Reply
Posted by
22swg
on 05 May, 2015 07:35
#7 Reply
Posted by
kaz911
on 05 May, 2015 08:34
don't forget that Microchip has lifetime warranty (slightly limited against idiot operators) - on many of their debug tools. I had a few broken PIC tools - I sent them back - and got them replaced (bought 2nd hand on ebay)
i dont believe what i'm hearing.
is it multitasking hatred or a nostalgia i'm not sure.
as for the clone advice. i dont know. the answer... maybe yes maybe not to all the questions. which one is the clone out of thousands? we dont know. simple general rule is... if you buy clone and it breaks next month (even though it can do all of the original functionalities) dont come and mourn to us, go to the seller and shout however you like... similarly if you buy original and it breaks, goto microchip... however, you are welcome to review either of them here so others get warned. cheers.
otoh i have pickit2 that just seemed to break last night, had it for several years now. several usb unplug-plug windows restart, change usb ports did not help, opening and brush cleaning the pcb/components did not help, checking all seems ok. so thinking without going further making unecessary damage, have faith pushing the red button and plug. it resetted itself and asked for the OS firmware, uploaded and its working like new again, thank you.
#9 Reply
Posted by
neslekkim
on 05 May, 2015 12:51
For those who have pickit2 etc:
http://www.microchip.com/pagehandler/en-us/promo/legacymigration/Edit: Shit, expired few days ago..
#10 Reply
Posted by
rolycat
on 05 May, 2015 12:58
#11 Reply
Posted by
ivan747
on 05 May, 2015 13:05
My 2 cents: there's nothing worse than debugging the debugger.
The price difference will give you peace of mind with the tool every time something goes wrong (and when programming micro controllers, that's often, see what happened to mechatrommer). And it's peace of mind that will last for years.
#12 Reply
Posted by
Howardlong
on 05 May, 2015 13:30
Agreed, there are enough "features" to fight with on the real thing without having to question the compatibiltiy of a no name.
#13 Reply
Posted by
diyaudio
on 05 May, 2015 16:24
Original or Clone PICKIT3 (Which I own) its dog slow, and to add to the frustration never seem to hit breakpoints during debugging. WTF?, im thinking of investing in a ICD3.
#14 Reply
Posted by
SuzyC
on 06 May, 2015 00:41
Thanks to all, I see now that saving a penny could cost me a dollar.
Not all the code I write works the first time..some of it does work the way I intended, most things take a little to a lot of debugging. And sometimes I find that my code works fine but my code is just not able to accomplish my pgm's goal. So, I need to debug my pgm flow.
I have never used a PICKIT3 (or any other debugger hardware sold by MCU producers), I have instead relied on hardware flag bits on MCU pins that trigger and display 1 to 4 output pins at the same time, with these carefully placed program set software flags displayed on my oscilloscope I can see the points in my programs I am interested in while watching the MCU perform a task. At the same time the MCU periodically sends a stream of data out to the PC using a RS232 TX pin to show a long list or arrays of var values.
So I debug using these var values which are continually updated and displayed on my PC with my own program (and then I am able go back to look at data saved in files on the PC for analysis.) My program then allows me to page through stored data after a test session.
I can see the realtime behavior by watching the bit flags on my 4-chan storage oscilloscope( and so the storage scope can also allow me to playback and review many seconds to hours of program operation). I transmit a timestamp at the start of each streamed packet so I can relate the flags stored on the oscilloscope display to the streamed data saved.
In this way the flags show program status and the data exposes var values.
Then it up to me to examine my program listing and compare my observation of pgm operation against this data to see expected and unexpected behavior. Finally, to fix the bugs I have to then look at my code and pseudo-code flow charts to try to figure out what I've got right or why what I've got is sometimes so amazingly wrong or where next to place flags to clarify how to solve the problem.
How is using a PICKIT3 any better than my method to debug with?
#15 Reply
Posted by
mazurov
on 06 May, 2015 01:32
I use both. Debugger allows stepping through code and set traps inside exception handlers. Have you ever tried to catch memory alignment trap with an oscilloscope (or a terminal)? Speaking of terminals, I suggest learning about DMCI - much better way of outputting arrays and vars.
#16 Reply
Posted by
SuzyC
on 06 May, 2015 02:35
What I am saying is that my primitive methods are able to be used with any MCU, independent of having an emulator or ICE or other MCU development board specific hardware, just requires use of a RS-232 TX pin and maybe 1 to 5 other pins on the MCU to identify pgm events and to store data that can be graphed or analyzed.
DMCI may not be so useful as difficult and time-wasteful to be continually tuned and set up to watch real world pgm operation when there are many physical forces acting in a complicated manner and also changing in a random way. It is not so easy then to use something that difficult to emulate using debugging software, it could be that the result is too myopic in its scope of the entire dynamic to see overall pgm operation, to see more clearly that which is challenging a pgm's strategy to accomplish some control goal in a realtime situation.
My intention is to not to question other debugging tools while only praising my own methods as the better alternative.
I am not trying to say my methods lead to the better or the worse, everyone has those tools which they have become best accustomed to use to solve debug problems. I also know there is more than one way to skin a cat.
I am just wondering why anyone would want to attempt to use the a PICKIT3 for this purpose.
#17 Reply
Posted by
BradC
on 06 May, 2015 02:51
I do what you do. A LED and a CRO are my preferred tools, but having the ICD3 (because it's a _lot_ faster than the PICKIT) sometimes I also like the ability to set a breakpoint and be able to single step. You don't need it, but once you have it you will find uses for it.
I started with the old Picstart back in the early 90's, from there to the Picstart+ and then to the PICKIT2. The ICD3 was just the natural progression. Each iteration just gets faster and more versatile. I don't really use the debugging features of the ICD, but sometimes the ability to break and step saves a few instrumentation/compile/test cycles. Frankly if MPLABX supported my PICKIT2 properly I'd not have bought the ICD3, but it doesn't so I did.
Generally first thing I bring up on a new platform is a serial monitor and go debugging from there, but the LED and the CRO always get a good workout. I've only got 2 channels and a shallow sample depth, but it's generally enough.
#18 Reply
Posted by
SuzyC
on 06 May, 2015 03:05
There is no need to have an expensive emulator/IDE/Simulator etc to have the ability to single step. A few lines of code and a start/stop switch on a pin can easily accomplish this with your own tiny custom "dbg();" routine that can be inserted into the code at any number of pgm points or inside an exception handler or software var value trap. One can even use one of the MCU's timers to slow walk through troubled code when an exception or event is triggered, and so it can slow down the pgm code and output values on each call.
now you start making sense. i use your method too but the limitation is we cant exactly pinpoint at which line the error code is, we can narrow it down to some smaller area but cant to exactly one line of code except some >1 iterations of debug-compile-upload process. i'm not sure if the debug ide or proprietary hardware facility like jtag can do real single stepping+regs/vars/memories view, not simulated single stepping in windows ide. i think they can but i have no time to learn. my app is simple, your method is workable.
edit: debugging embedded is quite a different arena than pc sofware development where you have realtime input data that you cant simply make a perfect simulation in sw (called stimuli in avr studio) thats why i keep hesitant to believe jtag or other proper way may work based on real life input...
#20 Reply
Posted by
BradC
on 06 May, 2015 05:49
True, except I can modify my breakpoint without modifying the code or re-downloading the target.
I'm not trying to convince you of its worth to *you*, only letting you know where it is useful to *me*.
#21 Reply
Posted by
SuzyC
on 06 May, 2015 10:09
Thanks Mechatrommer and Bradc, please know I appreciate that you've given me some insight on the how and why your SW/HW methods have helped to solve your debug problems.
One thing that I've learned is I can easily waste hours to days playing debug when the most productive thing that I could really do is realize that I don't quite understand the dynamics of my pgm, or the problem to be solved, or how the MCU is working with the task at hand.
There is a pgming problem that needs to be solved, and to do this best requires me to step back away from the tests and debug break points and look at my code and data and flow charts and just think about the how and what I am doing with my code.
The goal is to discover what is correct and correct or improve on what is wrong. I welcome any SW/HW approach that is efficient to help me understand what is really going on, to find out what needs to be changed or fixed or improved to get things to work. A complicated IDE or debugging tool can sometimes only distract me from thinking about the big picture and so sometimes helps to make a time-wasting situation worse.
More often than not, I can easily fall in a trap of not thinking about how my pgm is trying to work, and instead sit hypnotized at the bench diddling around debugging what turns out to be an inappropriate and quite harebrained software strategy.
Sometimes I have to sleep on it, or take a long or short walk. Most often, with just a little debugging, I realize that by examining just a few results of my debugging, it is that my pgm is shouting at me to notice an obvious point that I am failing to see.
#22 Reply
Posted by
22swg
on 06 May, 2015 11:30
I was skeptical with PK3 debug before I began to use more advanced PIC's, With MPLABX it's ability to report register / memory / pin contents at a breakpoint , then to resume running is essential, no led or serial output will do that without some code timing / pin implications. It also helps in understanding the mcu workings in more or less real time.
#23 Reply
Posted by
bson
on 06 May, 2015 21:51
I use a combination of techniques. A 4x20 character LCD with an I2C backpack for displaying values like ADC readings, capture timing, decoded IR commands, event counters, calculated values, etc. Makes things like integer over/underflow very obvious and makes it easy to exercise the full range of inputs and outputs. A scope to check outputs. An interrupt-driven IR decoder and a Vishay 38kHz IR (38238) receiver provides all the buttons I need using only one input pin and a timer. Very breadboard friendly. Assert()s provide early failure and I make them simply stop with a message on the LCD so I can attach a debugger and see why it stopped. Even if they get compiled out in production builds they still provide excellent documentation about assumptions and correctness. At other times I explicitly add code to look for failure conditions (invariant checks) and set breakpoints in the error handling. Then once a design is functionally good I rebuild with __DEBUG and all instrumentation disabled and make sure it still works, then figure out the lowest clock it can work on, then measure power consumption (uA/nA for PICs) and implement idle/sleep functionality to reduce power consumption. Finally, I see what the smallest flash and RAM is that I can shoehorn it into and what I can do to reduce the footprint without impacting power consumption.
#24 Reply
Posted by
BradC
on 07 May, 2015 01:19
This is really "old school", but when I get backed into a corner with a seemingly intractable bug I resort to a comfy chair, hard copy printout of the offending source, pack of highlighters and glass of scotch.
