@Chet...
How 'bout, (stay with me on this one mmkay), build your transformer like a torroid but put your enameled copper windings where the core would normally be, then wind the core where the windings would normally be (with enamel insulated iron wire)... there won't be any eddy current losses and the coupling will be greater than 1:1, giving you the overunity you have always craved...
Actually that last part is one big load of Temperances cow farts, but the transformer manufacturing method is valid, used for audio coupling back in the day, and called 'a hedgehog'.
Hmm hedgehog farts, I wonder if that's been tried? 🤔
Also just a little hint for ya... just because you feel better doesn't mean you should stop taking your meds, and leave the facility...
As our friend lou would say, I hope you've learned something ...and goodnight vaginas...
