Author Topic: FNIRSI DLA-16 Plus / DLA-32 Plus Logic Analyzer  (Read 4939 times)
Offline TomKatt
  • Electro-BOOMER
Re: FNIRSI DLA-16 Plus / DLA-32 Plus Logic Analyzer
« Reply #25 on: September 15, 2026, 02:41:55 pm »
Also - what is meant by 'Max Collectable Frequency - 200MHz' ?   Is this the bandwidth limit for signals to be sampled ?   And from my minimal experience with high frequency measurements, I'm guessing that by the time you reach 200 MHz the probes are a bigger limitation than anything else...
I'm likewise unsure what is meant by 'Max Sampling Rate (Buffer Stream) - 4Gbit At low sampling rates, depends on the computer's memory size'...  I think they are conflating storage depth with sampling rate?
« Last Edit: September 15, 2026, 02:44:27 pm by TomKatt »
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline smk
« Reply #26 on: September 15, 2026, 04:23:27 pm »
are there any advanced trigger options?
The Windows software from FNIRSI has a tab for sophisticated triggers, but it is disabled. I haven't delved into this topic yet. In the moment the standard capabilities of Sigrok are more than enough for me.
According to the product description only the DLA-32 Plus has advanced triggering, the DLA-16 PLUS only has versatile triggering:
Versatile Triggering: DLA-16 Plus and DLA-32 Plus support rising-edge, falling-edge, high-level, low-level, and any-edge triggering for accurate digital signal capture.
Advanced Triggering on DLA-32 Plus: Supports serial and parallel triggering, with up to 16 configurable parallel trigger levels and flexible serial matching conditions.
The following users thanked this post: megabyte
Offline megabyteTopic starter
« Reply #27 on: September 15, 2026, 04:43:49 pm »
Thank you. Good catch. I haven't seen this information.
« Reply #28 on: September 15, 2026, 05:06:47 pm »
I interpreted it as the bandwidth.
I am not a native speaker and I have absolutely no idea what they mean by this sentence.
Offline TomKatt
  • Electro-BOOMER
« Reply #29 on: September 15, 2026, 08:17:05 pm »
That's a pretty big feature set discrepancy!  The ability to trigger on specific patterns or similar serial data can be the difference between identifying a problem quickly and luck of the draw.  Do they use different FPGA controllers or would this be a software constraint?
My DSLogic Plus has advanced triggering that has proven useful on multiple occasions.
Offline abeyer
« Reply #30 on: September 15, 2026, 09:06:18 pm »
Haven't looked closely at this one, but most of these USB logic analyzers support two modes of capture: a buffered mode where they store to onboard RAM as fast as they're capable of, and a streaming mode where they don't store in hardware at all and just stream the samples back to the PC over USB at a slower speed.
So I think that's meant to say that it has 4Gb internal sample memory that can operate at full speed or can sample at slower speeds over USB up to the RAM available on the PC.
Offline TomKatt
  • Electro-BOOMER
« Reply #31 on: September 15, 2026, 09:35:07 pm »
That's what I was thinking - but that should have been already addressed in their speed/streaming spec:
Max Sampling Rate (Stream)   [DLA16]1CH/1G, 2CH/1G, 4CH/500M, 8CH/250M, 16CH/125M   [DLA32]1CH/1G, 2CH/1G, 4CH/500M, 8CH/250M, 16CH/125M, 32CH/50M
That should be related to a USB 3 connection.
My DSLogic Plus USB 2.0 specs streaming speed as
—   3 channels: 100MHz
—   6 channels: 50MHz
—   12 channels: 25MHz
—   16 channels: 20MHz
« Reply #32 on: September 15, 2026, 10:19:49 pm »
Correct.
USB 3.0 supports up to 5 Gbit/s. I attempted to capture data using 4 channels on 1 Gbit/s in streaming mode using the Sigrok driver. Unfortunately, it didn't - a lot of errors appeared in the data. I suspect this is limitation of LA's hardware rather than USB 3.0 throughput.
Offline TomKatt
  • Electro-BOOMER
« Reply #33 on: September 15, 2026, 10:24:50 pm »
That must be where the 'Max Sampling Rate (Buffer Stream) - 4Gbit At low sampling rates, depends on the computer's memory size' text comes into play...  You might get it, you might not  :P
« Reply #34 on: September 15, 2026, 11:07:15 pm »
I made a naive attempt to swap the internal DLA-16 and DLA-32 identifiers within the Windows program's binary file. Upon launch, my DLA-16 was recognized as a DLA-32, and the advanced trigger settings panel became available. Unfortunately, the advanced trigger functionality on the DLA-16 does not work. It appears to be a hardware limitation (a resistor on the PCB or settings in the flash memory?).
The following users thanked this post: voltsandjolts
Online voltsandjolts
« Reply #35 on: September 16, 2026, 08:24:34 am »
The PCB has U38 128Mbit FLASH which is likely holding the fpga bitstream which is loaded to the fpga at power-on.
That bitstream could be specific to the PCB (16 or 32 channels, and trigger features).
« Reply #36 on: September 16, 2026, 08:30:01 am »
I connected to the serial port of the LA. There is nothing interesting there. There are only two strings and no reaction on typing or during signals acquisition.
BootLoader Init...
Jump To User Code!
« Reply #37 on: September 16, 2026, 09:37:08 am »
And the manual says you can use negative thresholds down to -5V. Is that really true?
Yes, it is true. See the attached screenshots.
The FNIRSI's software permits to set thresholds between -5V..+5V.
The channel 0 on the screenshots of the software is for the sine wave and the channel 1 is the logical toggling.
« Reply #38 on: September 16, 2026, 09:47:24 am »
I expect this is being done in a similar way to the Kingst threshold adjustment - see sheet 6 and 7 of schematic linked below. It uses the fixed input threshold of the fpga and offsets the input signal appropriately.
https://sigrok.org/wimg/2/26/Kingst_LA2016_LA1016_Schematic.zip
https://sigrok.org/wiki/Kingst_LA2016
« Last Edit: September 16, 2026, 09:58:57 am by voltsandjolts »
« Reply #39 on: September 16, 2026, 01:31:32 pm »
It could be. I dumped the flash (see the attached zip file).
