Author Topic: The uBeam FAQ  (Read 660933 times)
0 Members and 17 Guests are viewing this topic.
Offline StillTrying
  • Country: Broken Britain
Re: The uBeam FAQ
« Reply #1575 on: March 10, 2019, 05:23:03 pm »
I don't think uDream will be able to keep up with the number of companies desperate to incorporate this technology into their IoTs products. >:D
Offline PaulReynolds
Re: The uBeam FAQ
« Reply #1576 on: March 11, 2019, 03:50:06 am »
Some more info,
They claim being able to transmit 1W at 1 meter, hunderds of mWs at 2m and 10s of mW at 5m, but when asking a bit more details, this was for an unspecified receiver size, unspecified transmitter model and unknown alignment.
When they demo the system, they hold the receiver with fingers blocking parts of the beam, but not the white square. I assume this means it's at least safe enough so that it does not hurt.
The receiver they demo is not delivering measurable power  (2 wires you can connect to a meter, or some USB you can connect to a phone)  instead it has an array of approximately 14x16 red LEDs which are not very bright to look at. When it's working, only about a 1/3 of the LEDs are lit. Assuming the LEDs are 5mW LEDs, this would be translated to about 350mW of usable power at short distance.
The demo kit includes a slightly smaller receiver, approximately half the size.
The kit includes the small transmitter, which does not lock on receivers but rather has a fixed focus and is always on.
During conversation they said that
All components of the kit are commercially available and ready to go to production.
Its completely safe, when asking about Israel (demo was in Israel) they avoided the question.
They said it's certified as safe by a 3rd party, they avoided answering who is the 3rd party.
They avoided all questions about dBs in either side (transmitter or receiver).
Good info, reinforces everything from earlier. 1 Watt at 1 meter but still won't say how or demonstrate? Hmmmm. So when Techcrunch were told by uBeam in Nov 2015 that the system would do a minimum of 1.5W at 4 meters, and in many cases faster than a wire, were they 'mistaken'?
https://techcrunch.com/2015/11/07/wireless-power-charger/
Ultrasound at 145 dB or less won't hurt fingers over a few seconds. Concern at skin is over time of long exposure and heat build up, especially in hair. Other concern is if it's on the ear, does it generate subharmonics and cause damage? Also any long term effects if exposed for hours a day, day after day.
No info on dB levels is bullshit, that smacks of avoiding regulatory and safety standards, and I wonder if they even know what the limits are in Israel. Same with refusing to say who claimed it was safe - identity of the third party is critical to know validity. They need to look up the word 'certified' as well.
I would be very surprised if that LED detector did not have batteries in the frame to amplify any received signals, I've thought that they were only using that to show the beam, not to actually claim it's self powered. Were they actually claiming that was all from energy harvesting, no batteries?
« Last Edit: March 11, 2019, 04:31:18 am by PaulReynolds »
Offline StillTrying
Re: The uBeam FAQ
« Reply #1577 on: March 11, 2019, 10:36:13 am »
The smaller transmitter sends constant high power sound forward. Does not locate receivers and does move the beam. Does not ever stop transmitting. If you place a receiver in front of it, it can turn on an LED at ~1 ft.  They say its all made out of commercially available components and is ready to go to market. The receiver can move an inch or two sideways and still works.
Just the 1 LED? :-DD
I used to think the LED boards didn't have batteries but after the mac CES video I think the large one does now!
1TX > 0.5m > 1RX > 1LED  is impossible, I've tried it and only goto to about 7mm with 30Vpp on the TX.
« Last Edit: March 11, 2019, 10:48:27 am by StillTrying »
Offline sdpkom
Re: The uBeam FAQ
« Reply #1578 on: March 11, 2019, 03:39:21 pm »
Not 1, about 24X26 of them...., but only about 30% are lit at any time.
Assuming each LED is ~5mW LED, if all the LEDs were lit @ full power it would mean ~1+W of power.
About 30% of them are lit, at best, and most of the one's that are lit are dim (dim=10% of power), so I would say we're seeing here 50-200mW of electrical power going into the LEDs, at ~ 1 meter distance.
The spot seems like a ~100 cm^2  spot, assuming some 25% conversion efficiency, you get 2-8mW/cm^2 of sound,   or ~135-140dB @ the receiver.
@paulReynolds can probably estimate this much better.
The following users thanked this post: PaulReynolds
Re: The uBeam FAQ
« Reply #1579 on: March 12, 2019, 07:36:05 am »
There are so many unknowns now in what they are doing, and inconsistent reported statements from them, it's getting hard, even for me, to make good estimates as to power levels, however I'll return to the point I made earlier that I had assumed that the LED detector panel was not 'self powered' and instead had batteries to amplify any incoming signal. That would be pretty simple to have a board with a M by N grid each with an amplifier, a Murata receiver on one side, and an LED on the other. If it's self powered you'd see that really quickly with distance. They also wouldn't be doing demos where they use a small panel to light a single LED, as I heard they did at CES in the private show, if each Murata could light a single LED.
I'm not even sure what they are doing now, it just doesn't make sense to me, not even in a "lipstick on a pig" way. If you can do 1 Watt at 1 meter, show it, it's 33x better than Energous. If it's certified safe, release the study and prove it. If it's legal in a country you can say "under <insert dB limit here> at all points". If you can't charge for shit (kinda important), if it's not safe, and if it isn't (or you're not sure) that it's legal, then you might want to rethink your business plan and pivot PDQ because things aren't going to get better from here.
Basically, IMO, if they had what they're apparently claiming, it makes complete sense to go public with it all. That they don't is pretty telling.
Offline Howardlong
Re: The uBeam FAQ
« Reply #1580 on: March 12, 2019, 08:45:22 am »
Agreed, it seems bizarre that they're so cagey about the capabilities. Even companies that release product datasheets under NDA offer key specifications in a product brief.
Offline sdpkom
Re: The uBeam FAQ
« Reply #1581 on: March 12, 2019, 11:05:26 am »
The following users thanked this post: Kean, PaulReynolds
Offline StillTrying
Re: The uBeam FAQ
« Reply #1582 on: March 12, 2019, 12:03:32 pm »
https://youtu.be/azBzKWqUoXU?t=1421
Well that was impressive, :horse:
The LEDs were a bit dim, I can see super bright LEDs lit at about 1uA, 50Hz leakage through my fingers is enough to light them.
Their TX doesn't have a power on LED to solve the "not been plugged in problem" ?
« Last Edit: March 12, 2019, 12:24:53 pm by StillTrying »
Online Fungus
Re: The uBeam FAQ
« Reply #1583 on: March 12, 2019, 12:47:06 pm »
At least we know he's not pressing a secret button on the receiver to activate the LEDs.
(unless it's a double-bluff  :popcorn: )
Questions:
a) Why would it take 30 seconds to warm up?
b) The receiver is huge, why does nobody notice that it's going to need a humongous phone to work and that the space would be better used by simply adding a bigger battery instead of this garbage.
Offline EEVblog
Re: The uBeam FAQ
« Reply #1584 on: March 12, 2019, 01:56:22 pm »
I'm so... underwhelmed...  :=\
Offline StillTrying
Re: The uBeam FAQ
« Reply #1585 on: March 12, 2019, 01:57:35 pm »
I don't know, I'd guess with the power they're putting into the TX transducers their peak frequency changes a bit in the first few minutes of on, which probably then is not a very good match for the cold RXs. :horse:
Offline EEVblog
Re: The uBeam FAQ
« Reply #1586 on: March 12, 2019, 02:00:45 pm »
I have no doubt it's self powered, LED's a pretty darn efficient and even 100mW total would power those LED's.
Probably a sum of all the RX transducer for system power, then tap off individual transducer levels as well for individual mapping. Pretty easy dumb stuff.
Offline sdpkom
Re: The uBeam FAQ
« Reply #1587 on: March 12, 2019, 02:17:16 pm »
Questions:
Quite normal.
For starters, there must be some  "computer" of some sort to manage it all, and it should finish booting up....
components need to reach operating temperatures.
It also verifies there are no engineers in the audience, if there are any, it warns the operator.
Offline jrs45
Re: The uBeam FAQ
« Reply #1588 on: March 12, 2019, 08:32:45 pm »
I doubt it's even as complex as needing "system power".  Each receiver transducer would just have a little conversion circuit that drives the LED.  If even that - I wouldn't be surprised if each transducer was connected directly to its own LED.
Offline EEVblog
Re: The uBeam FAQ
« Reply #1589 on: March 12, 2019, 11:10:07 pm »
Questions:
Quite normal.
*snort*
Online Fungus
Re: The uBeam FAQ
« Reply #1590 on: March 13, 2019, 12:17:42 am »
Questions:
Quite normal.
Yeah, I guess it could be booting Linux or something. You'd think there would be a status LED though.
Re: The uBeam FAQ
« Reply #1591 on: March 13, 2019, 05:09:13 am »
For those who may be interested, I gave an interview on my opinion of the at-distance wireless charging space.
https://www.thewirelesssolution.co.uk/blogs/information/paul-reynolds
How long do you estimate it will take before we get true wireless charging for smartphones?
If you are looking for multi-meter, as-fast-as-a-wire charging for smartphones then I expect you are going to be waiting a very long time, I simply do not see that happening. Directing energy is limited by the laws of physics, especially if you wish to do so safely and at a reasonable price. Physics makes it difficult and inefficient, but not impossible – however -most of the current methods under development, such as RF and acoustic, all have to eventually face regulatory limits that are there for safety that simply don’t allow enough power to be useful.
« Last Edit: March 13, 2019, 05:20:39 am by PaulReynolds »
Offline drussell
  • Hardcore Geek
Re: The uBeam FAQ
« Reply #1592 on: March 13, 2019, 01:48:07 pm »
Or just LEDs wired directly to the individual transducers...
Really easy dumb stuff...  :)
Offline Howardlong
Re: The uBeam FAQ
« Reply #1593 on: March 13, 2019, 10:53:55 pm »
Questions:
Quite normal.
Can you run Linux in under a watt? Or do you need a wall charger for that bit?
Online Fungus
Re: The uBeam FAQ
« Reply #1594 on: March 14, 2019, 05:18:33 am »
You can go to the moon and back with a whole Watt...  :popcorn:
Offline EEVblog
Re: The uBeam FAQ
« Reply #1595 on: March 16, 2019, 12:35:21 am »
This may or may not be me with two people who may or may not have something to do with a company that shall remain nameless.
This photo will self destruct once efficiency hits zero.
Offline Kean
    • Kean Electronics
Re: The uBeam FAQ
« Reply #1596 on: March 16, 2019, 04:31:35 pm »
The question is which will self-destruct first - the photo or uBeam?
Offline LapTop006
Re: The uBeam FAQ
« Reply #1597 on: March 17, 2019, 05:45:41 am »
Easily. A PocketBeagle can idle at about half a watt. Actual usage is more like 3W however.
Offline Howardlong
Re: The uBeam FAQ
« Reply #1598 on: March 17, 2019, 03:43:04 pm »
Half a watt idle? You could go to the moon and back on that!
I guess I need to spend more time outside of my nanoamp world.
Offline Cyberdragon
Re: The uBeam FAQ
« Reply #1599 on: March 17, 2019, 09:25:10 pm »
But..."You can't even run a vacuum cleaner on 12 amps John!" ;D
*BZZZZZZAAAAAP*
Voltamort strikes again!
