Author Topic: Neoden 4 pick and place  (Read 822951 times)
0 Members and 19 Guests are viewing this topic.
Offline TheSteve
  • Living the Dream
Re: Neoden 4 pick and place
« Reply #450 on: March 01, 2016, 11:56:36 pm »
It also desperately needs an independent speed control for the Z axis.
Seriously? you can't set this independently...?  :palm:
No, if you slow the X/Y it also slows the Z. We would often prefer a a higher speed X/Y with a slower Z for fine pitched parts.
VE7FM
Offline elmood
« Reply #451 on: March 02, 2016, 12:45:38 am »
These are great points / bugs... Please add them to the collaborative page.
http://collabedit.com/hfe7r
Let me know if there is any trouble editing.
Offline Ichan
« Reply #452 on: March 02, 2016, 06:31:12 am »
@elmood, thanks for the video and the list - if only i already have the machine on my hand then i surely will add some on the list.
On your video, you use drilled hole as "marking point" right? What size is it? How is the resulted placement accuracy?
The machine expects the board reference to be your first part which is an absolute value from 0,0. The fiducial points are then are then a relative value from the first part. This isn't out preferred way of doing it.
The information above is just too important to be missing on the manual.
Edit: just check the tracking, my machine just received by the forwarder company in Shenzhen - hope they ship it to me asap.
-ichan
« Last Edit: March 02, 2016, 06:38:54 am by Ichan »
Offline thommo
« Reply #453 on: March 02, 2016, 07:13:04 am »
Guys, don't forget that 'Fiducials' can actually appear as 'components' in a BOM / PnP file eg. FID1, FID2, FID3, and the 'First Part' can actually be FID1 with its coordinates set to 0;0 if that's what you want [albeit with a DoNotPlace status for that component/FID1].
Offline Ichan
« Reply #454 on: March 02, 2016, 07:48:25 am »
When we generate pick and place files from the CAD the current origin point will become the reference point, not the first part.
"Mark points" on Neoden term are several coordinates to inform the position and rotation / angle of the board on the machine - it can be fiducials or any other precision reference mark.
-ichan
Offline rwb
« Reply #455 on: March 02, 2016, 08:12:42 am »
Exciting to see all this first hand knowledge come together.
Ichan how much do you have invested in the machine at this point?
Are you saving any money by running the boards yourself vs outsourcing the job? Just curious.
Offline RobK_NL
« Reply #456 on: March 02, 2016, 02:26:48 pm »
I was seriously looking at this machine, but all of what has been said here made me think again.
Plus, this video at 2:17 and 2:28 shows the machine happily placing some TQFP's that have been very obviously used and abused before.
I'll stick with my ancient DIMA Optimat for a while longer.
Tell us what problem you want to solve, not what solution you're having problems with
Offline Ichan
« Reply #457 on: March 02, 2016, 05:15:02 pm »
I pay about $12K for my machine order, will have to spend some more for the shipment later.
Well, not only for my own job i take outsource job too in here - like the current job which is waiting for the machine ;)
...at 2:17 and 2:28 shows the machine happily placing some TQFP's that have been very obviously used and abused before.
:) Interesting findings,  but i accept that as a positive thing ;D
-ichan
Offline TheSteve
  • Living the Dream
« Reply #458 on: March 02, 2016, 06:09:45 pm »
Well later today or tomorrow we plan to build two panels that have just under 1600 parts each(10x10 matrix). So we'll see how the machine does. No tough parts, all 0805/soic.
Some other bugs to report:
-When using a tray if there is an error it will display the incorrect tray number on the screen - it is always off by one.
-When we try to use 3 fiducial points it never seems to get the parts in the proper place, using only 2 seems to work fine.
VE7FM
Offline RobK_NL
« Reply #459 on: March 02, 2016, 10:07:22 pm »
-ichan
There's two more; at around 2:37 and 2:50
Would you accept a machine that places those "as a positive thing"?
Offline Jefferson
« Reply #460 on: March 02, 2016, 10:25:46 pm »
... hm ... why bent pins in the photo
Offline theatrus
« Reply #461 on: March 02, 2016, 10:43:35 pm »
Probably their firmware test unit with some damaged scrap parts run through it a ton of times ;)
Software by day, hardware by night; blueAcro.com
Offline rwb
« Reply #462 on: March 02, 2016, 10:48:21 pm »
I understand, they are just using the same parts over and over for demo's and testing.
It's not like they are making real boards in the training videos.
Offline Jefferson
« Reply #463 on: March 02, 2016, 11:24:12 pm »
it's clear, the sight has an offset, which is then adjusted. But the loss of speed is required.
Is it always exactly?
I find it hard to accept that the software for XP
Offline wraper
  • Country: lv
« Reply #464 on: March 02, 2016, 11:24:43 pm »
-ichan
That IC actually looks like it was desoldered. Even if not, there is some residue on it's bottom, probably adhesive from the sticky tape they used instead of the solder paste. Anyway, I don't think it is the machine itself which bent those pins but it happened while the part was salvaged for reuse.
Offline Jefferson
« Reply #465 on: March 02, 2016, 11:30:08 pm »
Flux is ... 100% believe my experience 30 years. It's not accurate, just laugh
« Last Edit: March 02, 2016, 11:31:41 pm by Jefferson »
Offline TheSteve
  • Living the Dream
« Reply #466 on: March 02, 2016, 11:38:02 pm »
-ichan
All that really matters from that picture is that the vision system correctly identified the leg outline and position of the chip so it can be placed accurately - which it looks to have done just fine.
VE7FM
The following users thanked this post: Fdr87CC
Offline rx8pilot
« Reply #467 on: March 03, 2016, 01:39:59 am »
My ancient 20+ year old machine will reject a QFP with one bent pin - which is a good thing.
Offline Ichan
« Reply #468 on: March 03, 2016, 03:34:00 am »
So i can use refurbished chip too with the machine  ;)
-ichan
Offline rwb
« Reply #469 on: March 03, 2016, 03:50:15 am »
@theSteve  Hey when you run those boards tomorrow will you take some video or pictures for us interested folk on here?  :-+
« Last Edit: March 03, 2016, 05:33:59 am by rwb »
Offline thommo
« Reply #470 on: March 03, 2016, 04:29:21 am »
2nd that RWB .. TheSteve!
In fact, if you had time, we'd even sit through an episode of a tripod-mounted real-time capture, from start to finish, with your narrative. Would be a great insight into what's ahead, and give Neoden a better understanding of how the machine/user interface operates.
@theSteve  Hey when you run those boards tomorrow will you take some video or pictures for us interested folk on there?  :-+
Offline Ichan
« Reply #471 on: March 03, 2016, 05:33:05 am »
+1
Good or bad please make some videos.
-ichan
Offline RobK_NL
« Reply #472 on: March 03, 2016, 11:19:08 am »
That was not my point and neither did I even suggest that.
My point is that the vision system on this machine obviously doesn't care about the fact that several pins are bent to the point of actually touching adjacent pins! That's just completely stupid.
Offline rwb
« Reply #473 on: March 03, 2016, 03:50:39 pm »
Robk_NL I think all you need to do is spend $20,000 + extra to get that software feature built in. The Neoden 4 is is a $8500 machine so you can't expect all the features of a machine that cost many times more than that.
Offline Ichan
« Reply #474 on: March 03, 2016, 08:52:22 pm »
I am curious, how much is the price of Dima ATOZ PP-050 with let say 48x 8mm feeders and full vision option?
-ichan
