Hi. Did you installed an older firmware than default in the instrument? If so, what was your default firmware? Thanks.
Hi, modification has been done with 1.3.9.6, which was updatet from initial version 1.3.9.5 @ delivery.
Finally after modification updated to 1.3.9.7
Regards
Thomas
Mine was at 1.3.9.8, dropped it down to 1.3.9.6 and was able to telnet on port 10101 with the file SSA3000X_telnet listed by tv84,
I didn't have to use a login or pw, when I tried it didn't recognize the commands, but it was displaying the Arago project logo and seem to be responding, I then typed in the following commands.
cd /
cp -R /usr/bin/siglent/usr/backup /usr/bin/siglent/usr/mass_storage/U-disk0/SA-backup
cp -R /usr/bin/siglent/firmdata0 /usr/bin/siglent/usr/mass_storage/U-disk0/SA-firmdata0
the progress bar on the SSA stopped at 60% so I waited about 20 minutes, I then pulled the USB out and re started the SSA, it was not bricked, then read the USB stick on the PC and the two files were in there. I tried the whole procedure again and this time after the two files were written to the USB stick by the SSA using SSA3000X_telnet I entered the following commands,
cd /
mount -o remount,rw /dev/ubi2_0 /usr/bin/siglent/firmdata0
cd /usr/bin/siglent/firmdata0
mv NSP_sn_bandwidth.xml NSP_sn_bandwidthx.xml
cd /
cd /usr/bin/siglent/usr/backup
cd /
sync
exit
didn't get any errors but after re starting the SSA it turned on just fine but no upgrades.
Any help would be appreciated.
