Author Topic: (Kicad) pcb design for water level sensor xkc y25  (Read 1205 times)
Offline Sefanoulis7Topic starter
  • Country: tr
« on: March 27, 2022, 02:24:14 pm »
When the sensor is in water, the led is on and it works with 12 v dc. I will use 12 sensors in the design of the card, and when the sensor does not see water, the led I used on the card will turn on and the relay and buzzer will work even if any of them are lit. I don’t have much experience for design. Can you help me with this?
Online Doctorandus_P
« Last Edit: March 28, 2022, 05:18:49 pm by Doctorandus_P »
The following users thanked this post: johnboxall, Bassman59, golden_labels
Offline simon mugo
  • Country: ke
Re: (Kicad) pcb design for water level sensor xkc y25
« Reply #2 on: April 12, 2022, 01:16:15 am »
this requires you to design a schematic that describes your idea. We have so many commercially available water level detectors and I could advise you buy one of them and have a look at its features, manuals, and operation then try implementing one. Thanks
