For prototyping, I would like to order a PCB/stencil pair with matching 2mm or 3mm alignment holes in the PCB and the stencil.
It's easy enough to add non-plated holes to the PCB and set the solder paste layer so there are matching holes, but will JLCPCB produce a stencil from the solder paste (GTP/GBP) gerber or do they process the solder mask gerber (GTS/GBS) gerber and use that?
If they use the solder mask gerber(s) to produce stencils I expect I can get round that by ordering the stencil separately, but it would be good to know.
Thanks.
