Hi, this is my first post on this forum.
For a few weeks I am researching for small scale reflow ovens. My budget is tight. T-762 is around 200$ and the max. money I can give is around 200$. But here is the thing: I live in Turkey!
Our customs office will consider this product as "commercial" and I will need to hire a customs counselor and pay warehouse expenses also. Which will double the cost of T-762.
So, I am planning to make my own reflow oven. But I have another problem... In Turkey we don't have toaster ovens!
The smallest ovens here are around 30 liters, with metal heating elements on them. My plan is to buy one of these, find a non flamabble insulation thing (like rockwool) and reduce the inside volume, then use custom length heaters on both bottom and top. Then I want to use raspberry pi to pid control the oven. I don't need any screens, buttons, etc. Just emergy stop probably, which is easy. The rest can be controlled through a pc or mobile phone with a browser. For Raspberry, I found this:
https://github.com/apollo-ng/picoReflowI found a infrared heater repair shop. They can cut the infrared glass in any given length and with resistant inside, it costs 7.5 Turkish Liras, which makes 1.5 dollars!
Thin IR heaters are two type here. 400w and 600w. My plan is to use 3 or 4 400w heater at bottom, 3 or 4 400w heater at top. So my plan is to have an oven, which is 2400w or 3200w. I want to reduce cold/hot spots as much as I can and increasing the number of heaters would help I guess... Bu also, increased heater number means increased thermal mass, which can cause more overshoot. Can overshoot be reduced with fine tuning? What do you say?
Also I will probably make my own reflector for heaters (by salvaging ir heaters) and L shaped aluminium covers to reduce the IR light directly hitting the components. That is a must, isn't it? Also, I want to use very thin aluminum sheet both top and bottom of the pcb area. They will be smaller than the tray itself, but bigger than the cards I want to populate.
What do you say? If I don't electrocute myself (220V would hurt alot!?), do I have flaws with my project? What should I consider? Do you have any recommendations?
