Author Topic: CB/MIC/avionics connectors from ebay - what's the brand name version?  (Read 2360 times)
Offline poorchavaTopic starter
  • Troll Cave Electronics!
I think we all know those connectors. They are used in CB radios, often in "eastern made" soldering equipment (eg. Xytronic). They come in varieties between 2 and 9 pins and in two sizes (normal and mini). They look like this http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20160706065917&SearchText=cb+mic+connector
I can buy them by trockloads on ebay, but I need to find them from a brand name manufacturer and they need to fit in the same holes in the front panel of the product (panels are already made, modification is hardly an option). Does anyone know what was the original part chinese have cloned?
Offline elecman14
I also believe Amphenol 91 series might work for your application. They are not cheap but really well made.
You could also see if Philmore Datak might also be a source. From what I have heard they may not be importing them anymore but it might be worth a check. http://www.philmore-datak.com/mc/Page%2054.pdf
Sadly, this is not an option. I need something that has identical dimensions as those chinese connectors, just higher quality.
Offline Kilrah
i've never seen a close equivalent.
To me they inspired themselves from a DIN connector, said "we need to add screw lock" and came up with that without copying an actual design with implied compatibility...
You can find some locking DINs but they're usually with a quarter-turn lock instead of a multi turn (which is a meh idea) and OTOH not the same dimensions.
Offline Howardlong
Edit sorry, link already mentioned.
« Last Edit: July 06, 2016, 08:07:47 pm by Howardlong »
Online janoc
These are not likely inspired by DIN ("MIDI") connectors. The microphone plugs were originally made by Foster in Japan, patented sometime in 1950s or so.
You can get some brand name ones here: http://www.universal-radio.com/catalog/parts/micconn.html
Also good info here:
http://www.eham.net/ehamforum/smf/index.php?topic=92727.0
Offline TJ232
  • www.esp8266-projects.org
    • ESP8266 Projects
I have used with good results some similar ones from here: http://www.cliffuk.co.uk/products/cliffcon/zc.htm
Plug Part Numbers:
    2 pole FC684212
    3 pole FC684213
    4 pole FC684214
    5 pole FC684215
    6 pole FC684216
    7 pole FC684217
    8 pole FC684218
90° Plug Part Numbers:
    2 pole FC684222R
    3 pole FC684223R
    4 pole FC684224R
    5 pole FC684225R
    6 pole FC684226R
    7 pole FC684227R
    8 pole FC684228R
Socket Part Numbers:
    2 pole FC684202
    3 pole FC684203
    4 pole FC684204
    5 pole FC684205
    6 pole FC684206
    7 pole FC684207
    8 pole FC684208
Datasheet: Cliffcon Miniature ZC Series Connectors
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
@TJ232:
this looks very good. Cliff only has one size, whereas there are "normal" and "miniature" versions of the chinese stuff floating around.
I guess I will order a few of those from cliff and compare the build quality against stuff from Ebay/Allegro/Aliexpress/etc.
Seems, like TME has some of those on stock.
My goal is to find something that looks as identical as possible to chinese connectors, but is far more durable and far higher quality (the equipment into which that goes is pretty expensive, somebody made a bad call of installing cheap-ass connectors in this and we have a problem..., it's just bad PR)
Offline Howardlong
These (those illustrated in your link) are called GX16 connectors in China. Search aviation connectors. If you want EXACTLY the same size with high quality, search on Alibaba, not AliExpress, and contact the mfg to make a custom batch with higher quality control standard and better raw materials.
Somewhat ironic too, I've never seen these connectors used in aviation. Proper Amphenol ones, yes, but not these.
