I am considering to try a hotair station for soldering (I havent used any before), for working on prototypes, low component count, small boards, 2-4 layers, not too small SMDs (I usually work with 1206, 0805 passives and 0.65-0.5mm pitch ICs, usually soic and tssop). Is it worth to try and use one ? and to what specs I should pay attention ? I see usually air flow is 100l/min but there are units with lower numbers too. I prefer a well known brand.
