Loading [MathJax]/extensions/Safe.js
Author Topic: different color silkscreen  (Read 2660 times)
Offline riktwTopic starter
« on: October 21, 2013, 03:25:42 pm »
Hello,
I saw the PCB of the Mojo FPGA board on adafruit and what immediately got my attention was the black PCB with green silkscreen.
It really looks wonderful and I would like to know if there are PCB manufacturers who can make this?
http://www.adafruit.com/products/1553
Best regards,
Rik
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: different color silkscreen
« Reply #1 on: October 21, 2013, 03:33:15 pm »
Most manufacturers will do any colour combination you want, but there may be a 1-off cost, and possibly a minimum if they need to get a special ink in.
Day Job: Mostly LEDs
Offline KJDS
    • my website holding page
« Reply #2 on: October 21, 2013, 04:46:45 pm »
I used to use different coloured solder resist when I had two very similar boards on a production line at the same time. When the only difference in the boards is a couple of different resistor values it made for easy identification. Most board manufacturers can offer a range of options, but unless you are buying a lot it will cost.
Offline kizzap
« Reply #3 on: October 22, 2013, 12:27:18 am »
Last time I used a custom colour PCB I used goldenphoenix to get a panel made. Decent quality, and isn't all that expensive. Lead time wasn't too bad either.
-kizzap
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
