I have a board I've designed, and I feel it's nearly ready for me to get a small batch made. I'm aiming at using one of the cheap Chinese manufacturers (e.g. Seeed, Elecrow, PCBWay, et al). This will be the first time I've had some proper PCBs made, and I have a nagging doubt about whether I need to be concerned about my drill sizes.
The patterns/footprints for all the through-hole components I've been using have mostly been straight from my software's default library, without modification. And for a few other uncommon components, I've followed the exact dimensions the manufacturer recommends in their datasheet. As a result, I have a wide variety of through-hole diameters - 16 distinct sizes in all.
It is my understanding that most of these Chinese board manufacturers only use metric drill sizes, potentially ranged in 0.05mm increments (although that's a guess, as hardly any of them specifically state that info). I presume, if presented with a drill file with non-metric sizes, they perform some kind of 'normalisation' process to convert the hole sizes to match the metric tooling they have? Does anyone have insight into what they generally do? Would they just round the sizes up to the next 0.05mm increment?
