Author Topic: Do you ask for "electrical test" with PCBs?  (Read 960 times)
Offline FaringdonTopic starter
« on: June 26, 2022, 01:54:28 pm »
When you order PCBs from China  and the selector offers you "electrical test"....is it worth selecting it?....i am speaking of just standard offline SMPS PCBs.
Is it worth selecting any of the test  methods offered?
« Last Edit: June 26, 2022, 02:41:05 pm by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
Offline ebastler
Re: Do you ask for "electrical test" with PCBs?
« Reply #1 on: June 26, 2022, 02:36:14 pm »
With the low-cost Chineses PCB houses I have used, the cost for electrical testing is zero. Hence yes, it's worth selecting it.  ;)
The following users thanked this post: Faringdon
« Reply #2 on: June 26, 2022, 09:58:41 pm »
Thanks, what if you choose the option with no testing or inspection...is that a bit dodgy?......(just so i can gauge it, i appreciate its so low price its worth getting testing)
Offline Gyro
« Reply #3 on: June 26, 2022, 10:04:25 pm »
Is spending your time (and parts) building a prototype board, only to find that there are one or more unknown shorts or opens a bit dodgy?   ::)
« Last Edit: June 26, 2022, 10:06:23 pm by Gyro »
Best Regards, Chris
« Reply #4 on: June 26, 2022, 11:56:01 pm »
Thnaks, may i ask, what do you think the chances of that might be, ie, if you didnt select the test/inspection thing?
Offline ebastler
« Reply #5 on: June 27, 2022, 06:51:04 am »
1.24% * board area [cm²] / (track spacing [mil])².
I just made that up, ignore it. But seriously -- the probability will depend on so many aspects of your board design and the manufacturing details, I don't think anyone can give you solid numbers.
Some low-cost vendor I ordered from a few years ago would typically send 11 or 12 PCBs when I ordered 10, which suggests to me that they expected one or two failures out of 10. That was for small, double-sided boards. Manufacturing processes may have improved since, but the fact that flying probe tests are still part of the standard offering indicates that the failure rates are not negligible.
Yours is a large 4-layer PCB, if I remember correctly. You will put a lot of time into populating it and bringing it up, and the parts will cost you money as well. There are more than enough things that can go wrong and cost you time to troubleshoot. I would not want to potentially lose days, plus the cost of having to build a second unit, due to some internal short on the board.
Offline jc101
« Reply #6 on: June 27, 2022, 04:06:02 pm »
I'd turn the question around, when would you not have PCB electrically tested to verify all the nets are valid and there are no shorts?
