Author Topic: Flux remover causes ESD damage?  (Read 1519 times)
Offline FaringdonTopic starter
« on: December 17, 2022, 10:11:00 pm »
Would you agree, this flux-remover with brush applicator can cause ESD damage?...Eg , if brushed over chips....we have a board with what appears to be an ESD damaged LTC3721-1, after brushing over it with this applicator. The brush is on the end of a plastic holder...as can be seen..
https://uk.rs-online.com/web/p/solder-flux-removers/2987921?cm_mmc=UK-PLA-DS3A-_-google-_-CSS_UK_EN_Power_Tools_%26_Soldering_%26_Welding_Whoop-_-Solder+Flux+Removers_Whoop-_-2987921&matchtype=&pla-338094537262&cq_src=google_ads&cq_cmp=10914490527&cq_term=&cq_plac=&cq_net=g&cq_plt=gp&gclid=CjwKCAiA7vWcBhBUEiwAXieItoe-NJq24bxvkWqM0WsfuVWHxM0W0hUXB8YSoTCI-WWMi-ETyhhASRoCJe4QAvD_BwE&gclsrc=aw.ds
« Last Edit: December 17, 2022, 10:41:33 pm by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
Offline Gyro
Best Regards, Chris
The following users thanked this post: Faringdon
Online jc101
Re: Flux remover causes ESD damage?
« Reply #2 on: December 18, 2022, 05:57:00 pm »
I often use something similar to clean flux after modifying prototype boards, never had any issue with ESD damage to any part.  It's Electrolube Aerosol Flux Remover
https://uk.rs-online.com/web/p/solder-flux-removers/2058449
I generally given them a squirt with the flux remover that has a stiff brush in the end and a scrub, then a squirt with isopropyl, another brush towards to the edges.  After that I give it a blast with compressed air to dry the board off.  I have a small oilless compressor rather than canned air, cheaper in the long run.
In fact, over the years, despite probably some pretty shocking treatment, I've never damaged anything with ESD that I've been aware of.
Online jpanhalt
« Reply #3 on: December 18, 2022, 06:15:12 pm »
The datasheet doesn't say that particular flux remover is "esd" safe.  Time to stop wasting time with hypotheticals, i.e., you can't prove something won't happen, and for Faringdon to do a controlled experiment.  The fact a SMPS of his design doesn't work may be consistent with ESD damage, but there are a lot of more likely reasons.
Online coppercone2
« Reply #4 on: December 18, 2022, 06:26:10 pm »
just get a ESD safe brush and don't use the thing on the can, its dodgy
The following users thanked this post: tooki, Faringdon
